muddy Posted May 21, 2012 Share Posted May 21, 2012 I need to know the tap size to order some bottoming taps to clear the holes in the block. Ta. Quote Link to comment Share on other sites More sharing options...
Boydie Posted May 21, 2012 Share Posted May 21, 2012 I'm fairly sure they are 12mm x 1.5 Quote Link to comment Share on other sites More sharing options...
ejparrott Posted May 22, 2012 Share Posted May 22, 2012 You need one of these these"]http://www.thomassmi...tive.html ! Quote Link to comment Share on other sites More sharing options...
western Posted May 22, 2012 Share Posted May 22, 2012 You need one of these http://www.thomassmi...tive.html ! try this link, one above doesn't work http://www.thomassmithfasteners.com/thread_detective.html?PHPSESSID=6ea7bfdd4119c519f63c7eec140b2db7 Quote Link to comment Share on other sites More sharing options...
muddy Posted May 22, 2012 Author Share Posted May 22, 2012 Thanks chaps, will order a thread finder but could do with anymore info ASAP needed the tap yesterday! I have both fine and course taps but neither seemed to work, fine spline I think 1.5 did start but started going tight 1/4 of the way down and started making me nervous. Will. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted May 23, 2012 Share Posted May 23, 2012 Offer up the tap to the removed bolt, if the threads fit into each other the tap is the correct pitch. Quote Link to comment Share on other sites More sharing options...
muddy Posted May 23, 2012 Author Share Posted May 23, 2012 They do/ did thats what baffled me. Ordered taps today, dad muttered something about unf and metric but signal dropped out so gawd knows see tommoro. Will. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted May 23, 2012 Share Posted May 23, 2012 If you are just cleaning holes rather than tapping can't you just use a head bolt and cut some groves across the threads with an angle grinder? (so it vaguely resembles a tap) Normally works fairly well to clean carp out of threads. Quote Link to comment Share on other sites More sharing options...
muddy Posted May 23, 2012 Author Share Posted May 23, 2012 Probably Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted May 23, 2012 Share Posted May 23, 2012 Lol, wouldn't want to stop a fellow tinkerer increasing their tool collection though Quote Link to comment Share on other sites More sharing options...
muddy Posted May 23, 2012 Author Share Posted May 23, 2012 One cant have too many tools. Quote Link to comment Share on other sites More sharing options...
