Josh NZ Posted June 11, 2012 Share Posted June 11, 2012 Ok, so i have just bought a PTO for my SWB landy. Paid a fraction of its worth, which was nice until i realised that im missing some important things. Its appears to be a centre PTO, and it seems to have all the parts that it needs to operate but after doing a bit of research it appears that mine is missing some form of pulley that goes on the end of it and it needs an engine governer or something..? Im new to the intimacies of Landies so any help from the expert bodies out there would be much appreciated! Or better yet, if anyone has access to these bits and would like to sell them or point me in a direction where i can purchase them, again, much appreciated. Thats what i bought... Quote Link to comment Share on other sites More sharing options...
Daan Posted June 11, 2012 Share Posted June 11, 2012 looks pretty colmplete, the output flange is landrover propshaft pattern or you can fit a flange to it. What is it you want to drive with the PTO? Daan Quote Link to comment Share on other sites More sharing options...
Josh NZ Posted June 11, 2012 Author Share Posted June 11, 2012 Hi Daan. I really dont know what can be driven off these.. can you explain if i do need the governer or pulley thing? and or what they do haha Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted June 11, 2012 Share Posted June 11, 2012 Some bits for you to look at, to keep you amused :-) Gearbox PTO.pdf HTH. Quote Link to comment Share on other sites More sharing options...
steve b Posted June 11, 2012 Share Posted June 11, 2012 Hi Jim The governor is only really required when you are using the pto to drive something like a large compressor or generator where the load varies and is heavy . The pto you have is the std mechanical pto unit , so will drive lots of different things with a bit of creative fabrication including a hyd. pump cheers Steveb Quote Link to comment Share on other sites More sharing options...
tacr2man Posted June 14, 2012 Share Posted June 14, 2012 The hand throttle assy is handy , but as mentioned the governer is only needed for running stuff that you need to try and keep at a steady rpm . The options are endless , limited only by your wallet or imagination ! Quote Link to comment Share on other sites More sharing options...
