Landy-Novice Posted June 12, 2012 Share Posted June 12, 2012 hello all. when changing my front discs, the wheel kept on spinning and this is with the hand brake on which i thought lock the transfer box which is constant 4wd so it should of locked the front wheels? and the diff lock is basically low range and has nothing to do with the diff(s)? by hand i can turn the prop happy as larry aslong as there is 1 wheel off the ground, this cant be right surely? Quote Link to comment Share on other sites More sharing options...
Quagmire Posted June 12, 2012 Share Posted June 12, 2012 The centre diff works just like an axle diff when not locked. For a min imagine looking down at an axle from above, with the left hand wheel locked- you would be able to turn the right one if it was up in the air. Now take that image and instead of left and right wheels you have front and back axles. Same idea. By applying the handbrake you are locking one side of the diff (if diff lock is not engaged). You are therefore still able to turn the wheel and the propshaft turns even though handbrake is on. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 12, 2012 Share Posted June 12, 2012 The hand brake only locks the rear prop, until the centre diff is locked. It's different to your old series Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted June 14, 2012 Author Share Posted June 14, 2012 ahh right, i was under the impression that it's permanent 4x4 It's different to your old series your telling me! im still trying to find the red and yellow levers Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 14, 2012 Share Posted June 14, 2012 It is permanent 4x4, it's just that the power is sent through three differentials. So even though it's permanent 4x4, it's still possible to only have one wheel spinning if you get stuck. Hence differential locks. Quote Link to comment Share on other sites More sharing options...
zim Posted June 15, 2012 Share Posted June 15, 2012 your telling me! im still trying to find the red and yellow levers there's something special about driving about in an old series that you're changing all the different gear sticks (gear, red, yellow, overdrive) whilst carrying on with a totally unrelated conversation to the passenger. G Quote Link to comment Share on other sites More sharing options...
