ThreePointFive Posted July 14, 2012 Share Posted July 14, 2012 Hi all, I have a new shape rear door and I need to get parts together to make it complete. Clearly the door interior handle, door card, glass and seal are different. What I need to know is are there any parts I can carry over from the old door? I understand there may be a new lock needed, what about the handle, door catch, door stay, seal to doorway on body, etc? I have a wiper motor that should fit, but no bracket, can these be bought separately? Quote Link to comment Share on other sites More sharing options...
western Posted July 14, 2012 Share Posted July 14, 2012 new type rear door http://www.numcat.ru/landrover/p/31/52733/ check link http://www.numcat.ru/landrover/p/31/52736/ lock mechanism http://www.numcat.ru/landrover/p/31/52738/ hinges http://www.numcat.ru/landrover/p/31/52737/ wiper motor http://www.numcat.ru/landrover/p/31/52892/ Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted July 14, 2012 Author Share Posted July 14, 2012 I appreciate the links Western, but the issue is more which of these parts are the same as for the earlier door, I want to buy only what I need, and reuse what I can from my current door. Quote Link to comment Share on other sites More sharing options...
dave88sw Posted July 14, 2012 Share Posted July 14, 2012 The door catch assembly is the same, so just move the complete unit across. The lock barrell etc is contained in the unit. I think the check strap is the same but dont hold me to that. The door aperture seal is the same so nothing to change on the car. Everything else is different unfortunately. Quote Link to comment Share on other sites More sharing options...
western Posted July 14, 2012 Share Posted July 14, 2012 hinges are the same too, with the links the 9 digit part numbers are the newest, so that should give you a list of parts for the newest type door/wash/wipe mechanism. Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted July 15, 2012 Author Share Posted July 15, 2012 Thanks guys, you've answered a lot of questions I had, now collecting the new bits together. Quote Link to comment Share on other sites More sharing options...
bmhor Posted July 16, 2012 Share Posted July 16, 2012 Thanks guys, you've answered a lot of questions I had, now collecting the new bits together. Having just done this, you can use the old wiper motor BUT you need to make a top hat bush to locate the motor shaft in the door as the new door has a bigger shaft hole than the old doors. I put the new door onto a G or H plate back tub and used the existing door stay etc. If you want to go for the later look, be sure to specify that you have a high level brake light when you order the glass as the connections to the light are copper tracks on the glass. I forgot! Bob Quote Link to comment Share on other sites More sharing options...
