Hybrid_From_Hell Posted July 29, 2012 Share Posted July 29, 2012 Hmmm I need some new injectors (one of the few "Original" parts on the engine The injectors are : Magnet Marelli IW 058 Order Code 214300501010 I cannot find anyone on the www that sells them, can anyone help ? Nige Quote Link to comment Share on other sites More sharing options...
Jon White Posted July 29, 2012 Share Posted July 29, 2012 Could you get your existing ones serviced and flow tested (no I'm not winding you up there are companies that do it) used to be a place in farnahm did it I think.... Jon Quote Link to comment Share on other sites More sharing options...
luke keeper of badger Posted July 29, 2012 Share Posted July 29, 2012 http://www.forzavx.com/gecu/hw/IW058-injector.pdf a quick goggle found this mm competition if nothing else should make it easy to find something to fit luke Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted July 29, 2012 Author Share Posted July 29, 2012 Yep got that page printed from yonks back - but website down phone number not working Nige Quote Link to comment Share on other sites More sharing options...
zardos Posted July 29, 2012 Share Posted July 29, 2012 Some in Germany possibly ebay link but for a Lancia Delta Same part in the UK http://www.deltainte...2&C2=3&id=23079 May we worth checking out. Might also be used in an Alfa Romeo but it seems to have a SKU of 214300501011 Which is one number off your order code Another page list the Alfa 155 155 (167) - 2.0 16V Turbo Q4 (167.A2B, 167.A2... 1995 01.92-12.97 INJECTEUR IW058/1 214300501011 Update This place lists the 214300501010 http://arielbs.com/b...?ID=029&Muovi=1 Also this Italian place lists them http://www.cieffepi....?idCategoria=12 It seems they might also be branded under Webber instead of Magnet Marelli Quote Link to comment Share on other sites More sharing options...
lrcounty Posted July 31, 2012 Share Posted July 31, 2012 Would a set of Bosch design III 36lb injectors fit instead? Apparently the Bosch injectors are 60mm long Oring to Oring. I bought a set of Bosch 19lb injectors second hand off eBay to replace my standard land rover 3.9 V8 items. They are fantastic. I just had to use a third Oring in the "extra" groove at the bottom, as there is no provision for a clip at the top on the Design III's. Cheers Andre Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 1, 2012 Share Posted August 1, 2012 Why not just fit some more easily found ones that have the right-ish flow rate? That's half the point of having megasquirt you know... Quote Link to comment Share on other sites More sharing options...
zoltan Posted August 3, 2012 Share Posted August 3, 2012 Have you tried Webcon? http://www.webcon.co.uk/ Quote Link to comment Share on other sites More sharing options...
zoltan Posted August 3, 2012 Share Posted August 3, 2012 Re-reading your thread title Nige, IW 058 isn't a PICO injector, PICO type is a 4 jet short body injector. IW 058 is a single jet Bosch style long beasty Quote Link to comment Share on other sites More sharing options...
