Injector sales company needed - PICO IW 058
Some in Germany possibly ebay link but for a Lancia Delta
Same part in the UK http://www.deltainte...2&C2=3&id=23079
May we worth checking out.
Might also be used in an Alfa Romeo but it seems to have a SKU of
214300501011
Which is one number off your order code
Another page list the Alfa 155
155 (167) - 2.0 16V Turbo Q4 (167.A2B, 167.A2... 1995 01.92-12.97 INJECTEUR IW058/1 214300501011
Update
This place lists the 214300501010
http://arielbs.com/b...?ID=029&Muovi=1
Also this Italian place lists them http://www.cieffepi....?idCategoria=12
It seems they might also be branded under Webber instead of Magnet Marelli
Would a set of Bosch design III 36lb injectors fit instead? Apparently the Bosch injectors are 60mm long Oring to Oring.
I bought a set of Bosch 19lb injectors second hand off eBay to replace my standard land rover 3.9 V8 items. They are fantastic. I just had to use a third Oring in the "extra" groove at the bottom, as there is no provision for a clip at the top on the Design III's.
Cheers
Andre
