godzilla84 Posted September 1, 2012 Share Posted September 1, 2012 Hi folks, I have recently removed the grille on my Disco to clean my radiator and intercooler and i have found that both are in a pretty bad way. Most of the fins are feeling pretty fragile and crispy. My first thought was to get both refurbed and im going to get it priced up on monday. Depending on what i get quoted for this, i may end up getting replacements. I dont want to faf around with fitting new pipe work so i want to get the correct ones. Is there a difference between the 200tdi and 300tdi intercooler/radiators in terms of the location of the inlet/outlet pipes? Many thanks, Mark (Godzilla) Quote Link to comment Share on other sites More sharing options...
Phillis Posted September 1, 2012 Share Posted September 1, 2012 The radiators are different, oil cooler is in the same place , not sure if same connections, the top is in the same place but the bottom is on the other side, Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 2, 2012 Share Posted September 2, 2012 I got quoted 140 to get my 300 radiator re-cored at Aberdeen radiator specialist, not asked them about the intercooler... might do that. Quote Link to comment Share on other sites More sharing options...
godzilla84 Posted September 3, 2012 Author Share Posted September 3, 2012 I have seen 300tdi radiators on ebay for between £100 - £140. On closer inspection, my intercooler has a little more life left in it so im just going to clean it out for the time being and get the radiator recored if i can find somewhere that will match the ebay prices. Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 3, 2012 Share Posted September 3, 2012 Watch out for "cheaper" radiators, a lot of the pattern part ones have plastic endssides, so it means the cooling elements are glued in place rather than soldered. I looked into it a bit, decided that a re-core as long as the rest of the radiator is sound is the better option, they usually pressure test and fix any other minor problems with them too. Quote Link to comment Share on other sites More sharing options...
godzilla84 Posted September 3, 2012 Author Share Posted September 3, 2012 Does anybody know the difference between part numbers BTP2275 and BTP2275R. The latter is labeled as Aluminium. Does this mean entirely aluminium. The former has definitely got the plastic sides which Maverik refers to above. Quote Link to comment Share on other sites More sharing options...
SPendrey Posted September 3, 2012 Share Posted September 3, 2012 The R typically designates the part is a Replacement, i.e. not genuine and not OEM. Quote Link to comment Share on other sites More sharing options...
Boydie Posted September 4, 2012 Share Posted September 4, 2012 I had my radiator recored with the standard core out of a Mack Dynatherm - it has a 4 row core (off set) using 1/2" tubes as againt the standard inline 4 row core with 1/4" tubes the cost was around AUD $540.00 but the reduced water temperature made it well worthwhile. It fits/solders into the existing LR heads without any modification - apart from being cut down in overall length - Quote Link to comment Share on other sites More sharing options...
western Posted September 4, 2012 Share Posted September 4, 2012 Does anybody know the difference between part numbers BTP2275 and BTP2275R. The latter is labeled as Aluminium. Does this mean entirely aluminium. The former has definitely got the plastic sides which Maverik refers to above. http://www.brit-car....hp?xProd=188970 R on the end might stand for Reconditioned too Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted September 5, 2012 Share Posted September 5, 2012 And while they are at it get them to drill holes in the plates that separate the top half from the bottom half of the rad. This seems to be a design fault. Anyway, drill holes and then the radiator works better. Quote Link to comment Share on other sites More sharing options...
Boydie Posted September 5, 2012 Share Posted September 5, 2012 The drilled holes allow any air trapped in the bottom half of the radiator to travel to the top of the radiator and then out to the header bottle Quote Link to comment Share on other sites More sharing options...
godzilla84 Posted September 6, 2012 Author Share Posted September 6, 2012 I have found a place near me in Liverpool that will re-core the original radiator for £144 so i am going with that option. They have said they can do the same to the intercooler for £90. Quote Link to comment Share on other sites More sharing options...
