carlosbeldia Posted September 29, 2012 Share Posted September 29, 2012 I need to take this bearing out, it's really worned (number four in the diagram).... Quote Link to comment Share on other sites More sharing options...
western Posted September 29, 2012 Share Posted September 29, 2012 this manual should help R380 gearbox overhaul on http://landroveroneten.com/ Quote Link to comment Share on other sites More sharing options...
carlosbeldia Posted September 29, 2012 Author Share Posted September 29, 2012 It´s not clear in this stand, only says you have to take the front cover, but it seems you can extract it without dismantling the whole gearbox Quote Link to comment Share on other sites More sharing options...
western Posted September 29, 2012 Share Posted September 29, 2012 I haven't done that job, drop a e.mail or PM to Dave Ashcroft. he willl know. Quote Link to comment Share on other sites More sharing options...
Team Idris Posted September 29, 2012 Share Posted September 29, 2012 For that sort of bearing I would remove the roller cage with a chisel and use this puller; http://www.toolsource.com/split-plate-bearing-remover-j2291201-p-109405.html And run long threaded rods to the end of the shaft and a plate with two holes in it But putting it back on would be more of a worry for me. If you can drop it on hot all will be well, but I would be cautious of hammering it on, incase you damage the input-output shaft thrust bearing (If it is a needle bearing). Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted September 29, 2012 Share Posted September 29, 2012 If that bearing is worn then i'd expect the rest of the box to be well worn as well. The proper way is through the rear of the box. Quote Link to comment Share on other sites More sharing options...
carlosbeldia Posted September 30, 2012 Author Share Posted September 30, 2012 Damn it! I'm really in a lot of trouble with this, I don't dare to give the gearbox to a local mechanic (mine is almost the only Defe in town) and I'm not able to make the work by myself.... it seems at the end I'll have to buy a recon from Ashcroft... Quote Link to comment Share on other sites More sharing options...
DaveSIIA Posted September 30, 2012 Share Posted September 30, 2012 You can remove the front half of the case and (with a bit of easing) lift the input shaft off the front of the mainshaft. Best stand the box nose up to do this. As others have noted though, if this bearing is shot, I'd be inspecting / replacing the rest or consider a full reconditioning of the box. The job isn't difficult if you follow the instructions in the mauals linked by Western. Quote Link to comment Share on other sites More sharing options...
Muttland Posted September 30, 2012 Share Posted September 30, 2012 Hola Carlos: Aquí tenes las herramientas especificas para LR: http://www.dingocrof...alog/Tools.html http://www.dingocroft.co.uk/cgi-bin/sh000001.pl?REFPAGE=http%3a%2f%2fwww%2edingocroft%2eco%2euk%2facatalog%2fChurchill_ Tools%2ehtml&WD=r380&PN=Gearbox_Tools%2ehtml%23aLRT_2d37_2d024#aLRT_2d37_2d024 Espero te sirva Quote Link to comment Share on other sites More sharing options...
carlosbeldia Posted October 1, 2012 Author Share Posted October 1, 2012 Gracias compadre, pero es que esas herramientas son demasiado costosas, me toca mandarlo a un especialista, pero yo trabajo con el carro y ya va para dos meses que no produzco un centavo. Tomé la decisión de armar como está y pedir el kit para reparar, cuando llegue (en un par de meses) bajo la caja nuevamente. I have no money at this moment, I have just decided to put everything together as it is right now and wait for a recon or a repair kit (I work with my car and now there have been two months with no a dime on me). I only hope it holds...... wish me luck. Thanks everybody for your help Quote Link to comment Share on other sites More sharing options...
