Big.Mike Posted October 8, 2012 Share Posted October 8, 2012 Hi everyone, Does anyone know the thickness of the floor panel on a 110 csw load area? Cheers, Mike Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted October 8, 2012 Share Posted October 8, 2012 Not quite what you were asking but YRM do a replacement one in either 2mm or 3mm thick. http://www.yrmlandrover.com/epages/BT3575.sf/en_GB/?ObjectPath=/Shops/BT3575/Products/145/SubProducts/145-0001 Quote Link to comment Share on other sites More sharing options...
ejparrott Posted October 9, 2012 Share Posted October 9, 2012 I think the originals are the 2mm Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted October 9, 2012 Share Posted October 9, 2012 I replaced mine with a sheet of 2mm, cut to size by my local sheet metal supplier. I used sikaflex to glue 2cm channel underneath to replace the eroded strengtheners (though I lefts the ends on and pushed the channel up inside them). The steel cross braces I had shot blasted and then galvenised. Most of them were fine and the couple with a few holes were still structurally sound enough to reuse. Quote Link to comment Share on other sites More sharing options...
JeffR Posted October 9, 2012 Share Posted October 9, 2012 Having done this recently, 2mm was the thickness. Quote Link to comment Share on other sites More sharing options...
Snagger Posted October 9, 2012 Share Posted October 9, 2012 1.3mm is standard. I made one of 3mm hardened marine grade alloy; no more dents or buckling! Quote Link to comment Share on other sites More sharing options...
Big.Mike Posted October 10, 2012 Author Share Posted October 10, 2012 1.3mm is standard. I made one of 3mm hardened marine grade alloy; no more dents or buckling! Eek, 1.3mm is nothing... I was going to fit some unwin tracking and mount minibus seats to the load area... Some large spreaders might need to be made... Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted October 10, 2012 Share Posted October 10, 2012 Having done this recently, 2mm was the thickness. Didn't you do it twice Jeff? Quote Link to comment Share on other sites More sharing options...
JeffR Posted October 10, 2012 Share Posted October 10, 2012 Didn't you do it twice Jeff? Actually it's four times now! But we don't want to talk about that at the mo........Will not be doing again as the bar steward is screwed, glued, riveted, bonded and is stronger that a strong thing. Quote Link to comment Share on other sites More sharing options...
