nickdefender90 Posted October 28, 2012 Share Posted October 28, 2012 i have been trying to get the rear wiring loom back down through the chassis. i want to put in the rail as i dont think having outside is a good idea. has anyone done this and what is best thing for doing it. Thanks nick Quote Link to comment Share on other sites More sharing options...
western Posted October 28, 2012 Share Posted October 28, 2012 not an easy job if there is no string to pull it through with, if the chassis is in the normal position. I changed mine from inside to outside, put it in some split convoluted tubing & ran it along the top face of the chassis rail, tywrapped to pipes/brackets, it's well out of harms way & easy to get to if I want to run extra wires to the rear end. Quote Link to comment Share on other sites More sharing options...
bluehaze Posted October 28, 2012 Share Posted October 28, 2012 Couldn't get mine through when I replaced the chassis - settled for the same solution as Western. Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted October 28, 2012 Share Posted October 28, 2012 I used an electricians draw cord, it worked really well on mine :-) Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted October 28, 2012 Share Posted October 28, 2012 If you do try and do it make sure to remove the bolts from the shock top mount and the gearbox cross=member on that side as it will make it considerably easier. Do it in stages using stiff but pliable wire. Thread from one hole to the next using a loop of string to fish the end of the wire out of the hole so you can then pull a string through behind it. Repeat to next available hole in chassis until you get to the back. I did this but it still took a morning to get a string right through (110). The string is still there as in the end i decided to fix it above the chassis anyway!! Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted October 28, 2012 Share Posted October 28, 2012 To be fair, mine was a bare chassis, which helped, but yeh, going from one hole to the next to get a draw line through is the way to do it........... Quote Link to comment Share on other sites More sharing options...
Frax Posted October 28, 2012 Share Posted October 28, 2012 I did the same as Orgasmic farmer, used heavy earth wire with a loop on the end in an effort to get it to up and down the curves, used string at the end to fish it out. I then the loom inside a rubber tube and pulled it all through with the earth wire. It is not easy but doable. Quote Link to comment Share on other sites More sharing options...
Buzza Posted October 28, 2012 Share Posted October 28, 2012 I used the inner part of an old speedo cable, and the same as others have said, from one hole to the next. Quote Link to comment Share on other sites More sharing options...
jbs Posted October 29, 2012 Share Posted October 29, 2012 I used a length of brake pipe when I did mine, I had me at the rear end of the chassis and a mate of mine feeding the loom through the small-ish hole at the front of the chassis so It wouldn't get trapped John Quote Link to comment Share on other sites More sharing options...
C18RCH Posted October 29, 2012 Share Posted October 29, 2012 put mine inside some cable armor and ran it down the outside. Figured it's easier to access to fix if something does go wrong. Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted October 29, 2012 Share Posted October 29, 2012 Even inside the chassis I put mine in conduit, just in case there was any sharp galv sticking out that you can't see. Quote Link to comment Share on other sites More sharing options...
