Defender 110 / Classic RangeRover
I saw an article in a landy mag a few months ago that stated that the original CSW was on a 100 chassis - it had a shortened rear end.
That's not right. LR did make a few 100" prototypes for the Swiss army, at least one of which had three doors (standard front doors and a specially made rear door on one side only), but the original CSWs were Series vehicles, not Defender forerunner 90s/110s, and so had very little in common with RR chassis.
A RR/Defender hybrid will need new outriggers and rear cross member and a host of altered or added brackets, but it has been done most famously on "A 4x4 Is Born" (TV series). It's not the rear of the tub that needs shortening but the front, which is not an easy job to do neatly. I would not recommend extending a 100" chassis to 110" as I believe the depths, and thus strength, of the main rails is much less on the shorter chassis.
