Propshaft yoke collar seal?
twodoorgaz
Hi,
I'm about to start reassembling the two propshafts for my 1972 SIII SWB after a fell strip, clean and repaint.
The propshafts yoke has a threaded collar on the sliding joint, which I had to remove. Inside this collar was the remains of a seal presumably to hold the joint together and to keep the grease in. The front prop had a rubber/cork seal while the rear prop had a sprung metal seal - a bit like a piston ring oil scraper.
Problem is that these aren't shown in my parts manual and I can't find a single reference to them online.
Anybody know where I can get such a seal? I may have to measure up and just get a generic rubber oil seal to fill the gap.
Thanks in advance.
