walace58 Posted February 17, 2013 Share Posted February 17, 2013 My fuel flap actuator won't return to normal position so flap can be pushed shut. Motor works but shaft does not extend far enough to put catch back in position. Have tried Wd40 etc. It is 1994 model. no part number on actuator just Maker, 'Kiekert 6, W germany'. Not available as a spare. Was this fitted to any other car at that time, perhaps Ford or BMW? Does anyone have an exploded diagram of this item? I have tried to dismantle but 'lid' seem to be very well fixed. It might need sawing off. Thanks, walace58 Quote Link to comment Share on other sites More sharing options...
DrRob Posted February 17, 2013 Share Posted February 17, 2013 Think you can buy them new still...... Quote Link to comment Share on other sites More sharing options...
western Posted February 17, 2013 Share Posted February 17, 2013 see my reply in the 'request for part numbers forum' http://forums.lr4x4.com/index.php?showtopic=81857 Quote Link to comment Share on other sites More sharing options...
walace58 Posted February 17, 2013 Author Share Posted February 17, 2013 Thank you. investigating reply from our parts numbers specialist. walace58 Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted February 18, 2013 Share Posted February 18, 2013 I've just taken one off an '89 (did they have the same part?) but I don't know if it works, I can test it if you can tell me how. Is it 12v in one direction for open and the other direction for closed? If it works you can have it for the cost of postage, saves me putting it in the bin. Quote Link to comment Share on other sites More sharing options...
walace58 Posted February 20, 2013 Author Share Posted February 20, 2013 Hi Cynic- al - thanks for your offer, I don't if same actuator as manual is for 92- 94. I have got mine working by putting WD40 init, it took till monday morning to work, so now refitted. If you want to test yours, mine works by one application of the power, the catch is withdrawn into the body of the actuator, which allows the spring loaded flap to open. the motor appears to keep spinning allowing the catch to return to its original position waiting for the fuel flap to be closed. The part of the actuator, 'spindle/shaft', is now locked into position, and can't be pushed into the actuator body, but the end latch 'spring loaded', can move under pressure of the lug on the fuel flap and this secures the fuel flap closed. If it looks like item 2 3 and 4 in the drawing attached and works, I would be interested http://www.numcat.ru/landrover/p/39/49057/ A very clever engineering solutuion , I think, its lasted for 19 years, lets hope for a bit longer. Western, as you see above , haven't had to buy a new one, do you know if the 1989 actuator is the same? Regards to all, walace58 Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted February 20, 2013 Share Posted February 20, 2013 I'll find it out and test it out of curiosity and let you know. Sounds like its a bit like a windscreen wiper with the auto park. Quote Link to comment Share on other sites More sharing options...
