need4speed Posted July 18, 2013 Share Posted July 18, 2013 Working on the TPS wiring today. The TPS itself looks really crappy. Looks as though its maybe even sustained a little knock at some time. This got me thinking: just how reliable are these? Would it be worth changing now? Id rather not if i dont have to as they arent exactly chip-money..... Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted July 18, 2013 Share Posted July 18, 2013 The wires get hot and coverings can crack They are remarkably strong, and MS can test them Right click any gauage, select TPS then push pedal down and see if 0-100% is smooth - if not its Fubared You will need to calibrate TPS 1st Tools > Calibrate TPS> ignition on and get top box (value 20-40 good, then push acel to floor get 2nd box 250-300 good if 1st box is high and 2nd low TPS wired back to front Nige Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted July 18, 2013 Share Posted July 18, 2013 I've had problems with the wire sheathing splitting where it comes out of the housing but that's about it. If you had an analog meter you could see if you get a clean variation in the range but at the end of the day it's not the hardest part to change. How much are they new out of interest? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted July 18, 2013 Share Posted July 18, 2013 Spendy !!! Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted July 19, 2013 Share Posted July 19, 2013 In that case I'd better get the silicon ready for the next time it cracks Quote Link to comment Share on other sites More sharing options...
need4speed Posted July 19, 2013 Author Share Posted July 19, 2013 Sounds like they are quite robust. I might risk fitting it then and testing with MS when the time comes. Cheers guys Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 22, 2013 Share Posted July 22, 2013 The 4.0 / 4.6 ones are nicer and have a plug on them rather than frayed wires which are the universal standard for the old-style ones. Quote Link to comment Share on other sites More sharing options...
