need4speed Posted July 24, 2013 Share Posted July 24, 2013 Am i correct in thinking that it is not essential for the PIP and SAW wires to be shielded? Phil Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted July 24, 2013 Share Posted July 24, 2013 Hmmmm best that they are really Its whats reconended Quote Link to comment Share on other sites More sharing options...
need4speed Posted July 24, 2013 Author Share Posted July 24, 2013 Ok Nige. Will i have enough shielded VR cable from your kit left over to do the SAW/PIP wires with that? Quote Link to comment Share on other sites More sharing options...
need4speed Posted July 25, 2013 Author Share Posted July 25, 2013 Scratch that. I obviously need single core screened. Not the 2 core which the VR is...... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 25, 2013 Share Posted July 25, 2013 I've never bothered screening them, neither did Ford. Ford do screen the VR sensor wires but I've never found that to be critical. Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted August 9, 2013 Share Posted August 9, 2013 I used left over screened VR cable for saw and pip but that was because my edis was in engine bay and ecu inside car Edis unit has some form of shielding on the wires originally! Quote Link to comment Share on other sites More sharing options...
Chazza Posted August 10, 2013 Share Posted August 10, 2013 Whether to or not, depends on how much EMF noise is close to the sensor wires and the easiest way to find noise, is to put an off-tune transistor radio next to suspect items such as the alternator, so that it can be heard. Separating the sensor wires from the source of the EMF, significantly reduces the chance that the EMF will interfere with the voltage signals in the item you are trying to protect. If the wires can't be moved far enough away, shield them. Remember that very low voltages can give false signals, Cheers Charlie Quote Link to comment Share on other sites More sharing options...
