Tom17 Posted July 30, 2013 Share Posted July 30, 2013 Hi all my back passenger side wheel is caked in grease or oil or something? What's up with it? What need replacing or repair? Cheers Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted July 31, 2013 Share Posted July 31, 2013 check your axle breather is clear, if it blocks the axle can pressurise as it heats up and blow oil out through the dust caps Quote Link to comment Share on other sites More sharing options...
Mutley Posted July 31, 2013 Share Posted July 31, 2013 Hub seal at a guess. Just did mine for the same reaso Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 31, 2013 Share Posted July 31, 2013 Inside or outside of the wheel? Quote Link to comment Share on other sites More sharing options...
ebygum110 Posted August 8, 2013 Share Posted August 8, 2013 as Ross says, inside the wheel or outside the wheel - guessing outside and its probably a blocked breather as has been mentioned, a longish journey and pressure builds up and blows the seal out. If you have perished hub covers like mine it just dribbles out and then flicks all over the wheel at speed. Replacement seals aren't expensive. Quote Link to comment Share on other sites More sharing options...
western Posted August 8, 2013 Share Posted August 8, 2013 check the hub plastic centre cap for splits if the grease is on the outside, if on inside hub seal or breather as mentioned above. Quote Link to comment Share on other sites More sharing options...
Tom17 Posted August 8, 2013 Author Share Posted August 8, 2013 check the hub plastic centre cap for splits if the grease is on the outside, if on inside hub seal or breather as mentioned above It's on the outside! But the cap seems fine Quote Link to comment Share on other sites More sharing options...
western Posted August 8, 2013 Share Posted August 8, 2013 Check the 5 bolts in the drive member inb centre of hub are tight, if the cap looks fine, it could still have a split, it needs to be off the hub for a good look & ensure it is fully seated on the drive member too. Quote Link to comment Share on other sites More sharing options...
Tom17 Posted August 9, 2013 Author Share Posted August 9, 2013 Check the 5 bolts in the drive member inb centre of hub are tight, if the cap looks fine, it could still have a split, it needs to be off the hub for a good look & ensure it is fully seated on the drive member too. A mate is claiming it the axle seal as if seems to be oil from the diff? Could this be the case Quote Link to comment Share on other sites More sharing options...
Mutley Posted August 9, 2013 Share Posted August 9, 2013 That would be the drive flange gasket? Quote Link to comment Share on other sites More sharing options...
western Posted August 9, 2013 Share Posted August 9, 2013 won't be diff oil on the outside of the wheel A mate is claiming it the axle seal as if seems to be oil from the diff? Could this be the case not on the outside of the wheel, more likely the cap or the suggestion above Quote Link to comment Share on other sites More sharing options...
The Badger Posted August 10, 2013 Share Posted August 10, 2013 Mine has done this about 4 times since I have had it, every time its the stub axle oil seal Quote Link to comment Share on other sites More sharing options...
