AndrewHorsfield Posted November 7, 2013 Share Posted November 7, 2013 Hi all, I am planning on fitting a Rev counter on my 2.5NA and about to buy a Durite one that measures form 0 to 4,000 revs. Is this the correct range for my engine please? Thanks in advance Quote Link to comment Share on other sites More sharing options...
western Posted November 7, 2013 Share Posted November 7, 2013 0 to 5000 might be better, my defender workshop bok says max revs is 4200 +/- 20rpm Quote Link to comment Share on other sites More sharing options...
Taffia Posted November 7, 2013 Share Posted November 7, 2013 Hi all, I am planning on fitting a Rev counter on my 2.5NA and about to buy a Durite one that measures form 0 to 4,000 revs. Is this the correct range for my engine please? Thanks in advance Hi Was thinking of doing the same. Can you post some pics and how-to if you do it? Good luck Quote Link to comment Share on other sites More sharing options...
Ash.Witty Posted November 7, 2013 Share Posted November 7, 2013 The maximum governed speed of a 2.5N/A is 4400 Rpm, although its probably not a good idea to ever take it that high! Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted November 7, 2013 Share Posted November 7, 2013 If you get it to more than 4000 rpm regularly or for any extended period then the fact that your gauge is off the end of the dial will be the least of your problems! Quote Link to comment Share on other sites More sharing options...
AndrewHorsfield Posted November 10, 2013 Author Share Posted November 10, 2013 Thanks all. Sounds as though I might as well go with the up to 4,000 revs, as Durite do one at sub £50 for Alternator pickup. It will be a few weeks before I get chance to do it, but I will post my learnings when I do. Cheers Quote Link to comment Share on other sites More sharing options...
