gav- Posted December 28, 2013 Share Posted December 28, 2013 If a new injection manifold was made and a mega squirt assembly fitted to a series 2286 engine, would it make the engine more efficient, improve mpg and be more reliable? Is it worth the effort? I would have thought it would improve but anyone have an idea as to how much? Cheers Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted December 28, 2013 Share Posted December 28, 2013 It's been done. Using a throttle body injector unit off a small car. I had a link somewhere but lost it I'm afraid! Would most certainly improve MPG I should think. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 28, 2013 Share Posted December 28, 2013 Yes it would help loads I am sure, but you would still be left with an engine designed in the 1950s(or even 40s?). I'm not going to discourage you, it would make an awesome project. Simplest way is to bolt a single port injection throttle body onto the existing inlet, I think Bosch is often preferred. It has been discussed on here before, and someone even started doing it, but I don't think it got completed. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 28, 2013 Share Posted December 28, 2013 Here's a link, looks like it did get finished: http://www.melsteve.plus.com/LandRover/ Quote Link to comment Share on other sites More sharing options...
Chazza Posted December 29, 2013 Share Posted December 29, 2013 Is it worth the effort? That is really a question only you can answer. How often do you use the car and what sort of distances do you cover? It would definitely have better ignition and fuel economy. A chap in Sydney converted his using the injectors off a Honda and sundry other bits, Cheers Charlie Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 30, 2013 Share Posted December 30, 2013 I'd say go for it, proper fuelling & ignition will make a big difference over 40-year-old-clockwork, although it's never going to outdo modern stuff with 50+ years evolution behind it, it might make it that bit nicer. Also, very few people have done it to the 4-pot so it'd be good to have a few more. Quote Link to comment Share on other sites More sharing options...
