Cynic-al Posted February 12, 2014 Share Posted February 12, 2014 So this is just a bit of fun, we've bought a new 3D printer at work so the reprap has gone to the eBay of shame! I wanted to print something unimportant as a trial so came up with this... and seeing as you lot love a gadget why not share Modelled on CAD Send it to print, it prints in 28 micron layers of resin and it puts down a wax as a support medium. The bright white is the plastic and the lighter white is the wax. The underside is curved to match the bonnet so if you look closely at the top and bottom of the R it's just starting to put the plastic down for that. You end up with this which you have to de-wax. I asked it to print in matt as I want to paint it so it puts a layer of support material on every surface. A Gloss finish is stronger and doesn't need the support material but can of course only be applied to surfaces that don't need supporting! Finished part; Getting the wax out of the vents was a real pain so they might be replaced with mesh as I want to put 'RR' on either side I was trying to match this writing style, I will try to colour match it with spray paint. and well... you get the idea Quote Link to comment Share on other sites More sharing options...
Maverik Posted February 12, 2014 Share Posted February 12, 2014 Awesome, points for inovation and access to such a cool toy! Quote Link to comment Share on other sites More sharing options...
Nigelw Posted February 16, 2014 Share Posted February 16, 2014 Do it as V8 Like that Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted February 17, 2014 Share Posted February 17, 2014 Cool! Nice touch Quote Link to comment Share on other sites More sharing options...
bishbosh Posted February 17, 2014 Share Posted February 17, 2014 Great piece of tech but didn't I read somewhere that bonnet vents there are actually very bad for engine cooling? Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted February 18, 2014 Author Share Posted February 18, 2014 I honestly don't know, although I run a V8 overheating is not something I've ever had a problem with! I was just tarting around with the machine! I was more concerned about the fan pushing water through the vents and breaking the grill bit off I always assumed people did it to let the heat out whilst your idling and there is little airflow. I assume whilst your driving there is enough air flow to get the warm air out and under the car. Never thought about doing V8, I picked the R as it was easy to make hollow. Quote Link to comment Share on other sites More sharing options...
