Bingy Posted July 10, 2014 Share Posted July 10, 2014 So now the 4.6 is running i need to start to think about getting it to run properly I have read loads of threads and info - but its in through the eyes and out through the ears missing the tiny sponge bit in the middle have gathered that i need to set the ignition timing first of all need confirmation on one thing. been Reading again and again and again the A to Z MS thread, but sometimes there are some bits lost in translation to check the EDIS timing vs the trigger wheel i should: - disconnect the SAW wire (pink) from the relay board - start the engine, EDIS should set 10º limp home mode - with timing gun see whats the number on the cranckpolie - turn engine off - adjust if necessary the software triming, if timing gun shows 7º then i put -3 in the software triming - start the engine with SAW still disconnected - check timing again with timing gun. is that it? Yup Or, you can set the idle cells to a fixed value e.g. 10, then check that the figure on the laptop matches the figure on the pulley. As Bowie says, if you make the idle cells (or to be pedantic "all the cells the engine will be in when idling") some fixed value, EG 10deg, then you put the timing gun on & adjust the trim angle until the timing is correct (number seen on pulley with timing light = value in ignition map where the dot is). Fairly straight forward....but the 4.6 doesnt have any marks on the pullies to reference to when the strobe light is attached any other way? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 10, 2014 Share Posted July 10, 2014 Yeah.... find TDC by putting a hollowed out plug into cylinder #1 with a bolt through it to it contacts the piston as it comes up near TDC, then fabricate/use an old pointer and fix to timing chest. Then wind engine one way, gently, until piston contacts bolt, and mark pulley. Then turn other way until bolt touches again, mark pulley. TDC is half way between marks, 10 degrees can be worked out with a protractor or a bit of maths from that mark. Quote Link to comment Share on other sites More sharing options...
Rangie46 Posted July 10, 2014 Share Posted July 10, 2014 I had the same issue with my 4.0 but do as Bowie says, I used a pencil in the spark plug hole,rotate crank pulley clockwise until pencil gets to highest point and make a mark where you have the pointer set, then continue to rotate until pencil starts to drop down then rotate back and make a mark when pencil is at its highest point, In between these two marks is tdc, then measure the circumference of the crank pulley divide by 360 and times by ten equals the distance for you to make another mark which is 10deg btdc, then in the spark table set all the buckets to 10 this will have it firing at 10deg btdc with your strobe adjust the trim in spark settings Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 10, 2014 Share Posted July 10, 2014 You can get sticky tape with timing marks on from Real Steel etc., just get the right one for the diameter of the crank pulley. Obviously you still have to find TDC first. Quote Link to comment Share on other sites More sharing options...
Bingy Posted July 10, 2014 Author Share Posted July 10, 2014 So i have a plunger in no 1 cylinder at tdc and the vr sensor lines up with the mark five teeth away from the missing tooth i have made a pointer level with the edge of a tooth on the trigger wheel trigger wheel is 36-1 i need 10 degrees so each tooth is 10 degrees apart apart from the missing tooth If i put a mark on the pulleywheel from the edge of the tooth previous this should be 10 degrees before tdc or is it not that simple?? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 10, 2014 Share Posted July 10, 2014 I always rotate the crank both ways and find the mid points, due to clearance in the bearings it will affect the position of the piston, and not trying to find the highest point of a rotating component, which is pretty difficult. Other than that though yes you have it Quote Link to comment Share on other sites More sharing options...
Bingy Posted July 10, 2014 Author Share Posted July 10, 2014 Thanks all, for once i done something right, lol Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted July 10, 2014 Share Posted July 10, 2014 Rotfpmsl .... Don't be so hard on yourself. .. Quote Link to comment Share on other sites More sharing options...
