minimaquinas Posted December 4, 2014 Share Posted December 4, 2014 i got a new distributor cap and leads and a rotor arm for my v8 110 but the old rotor arm was rusted on hence it broke when removing when i fitted the cap and rotor arm it refused to start but when i put the old rotor arm back in it started big question is what can go wrong with a rotor arm i am baffled any ideas tia Quote Link to comment Share on other sites More sharing options...
steve b Posted December 4, 2014 Share Posted December 4, 2014 Too much clearance between the contactors ? is the locating lug in the same place as the old one ? cheers Steveb Quote Link to comment Share on other sites More sharing options...
jad Posted December 4, 2014 Share Posted December 4, 2014 was it a lucas rotor arm? even new ones from other makes can be poop and cause terrible running/starting. Jad Quote Link to comment Share on other sites More sharing options...
mad_pete Posted December 4, 2014 Share Posted December 4, 2014 Many rotor arms are sold pre-broken to save you time as the owner having to wear them out driving your car. Quote Link to comment Share on other sites More sharing options...
missingsid Posted December 5, 2014 Share Posted December 5, 2014 Is there any lacquer on the brass? Even when in use fo a while I had to chip a lacquer type material off the contacts! Marc Quote Link to comment Share on other sites More sharing options...
mad_pete Posted December 5, 2014 Share Posted December 5, 2014 I would buy another rotor arm and try that. After a while I got in the habit of buying 2 at once and must expensive I could find as seemed to be easy to get a dud. Quote Link to comment Share on other sites More sharing options...
robertspark Posted December 5, 2014 Share Posted December 5, 2014 rotor arms are a bit of consumable item on a rover v8 (hence why EDIS is the chosen modification with what would appear to be very high reliability). there is nothing that defines a good of or a bad one at first purchase, I always kept a tested and working spare in the battery box sealed in a sandwich bag as I was once stranded in the middle of nowhere, and replaced that when the working one failed and I needed a spare. Quote Link to comment Share on other sites More sharing options...
