Disco-Ron Posted December 27, 2014 Share Posted December 27, 2014 I'm going to be re routing the transmission cooler pipes on my 90 and wondered if I can get away with cutting the original metal pipe alongside the engine sump and simply using half inch rubber pipe with clips. Or is the pressure likely to blow the pipes apart.... Thanks Quote Link to comment Share on other sites More sharing options...
Team Idris Posted December 27, 2014 Share Posted December 27, 2014 According to Ashcroft it can go high when it goes into lockup? I've had 3/8" rubber pipe on for ages, but I rarely take it out of second gear. I can say for sure that those intercal coolers everyone uses don't do much over 100psi, and that should be well within rubber hose capability. Double hose clip and good hose should do it. Quote Link to comment Share on other sites More sharing options...
Escape Posted December 27, 2014 Share Posted December 27, 2014 Quentin used rubber hose with good clips to move the cooler lines when fitting a Bosch 4.6 to his RRC, and they seem to be holding OK. Has been used both on the highway (with lock-up) and under heavy load. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 27, 2014 Share Posted December 27, 2014 It's low pressure in those pipes, it's the return from the box, so all the energy is gone, with barbed fittings and hose clips you should be fine. Quote Link to comment Share on other sites More sharing options...
toenden Posted December 27, 2014 Share Posted December 27, 2014 Hi Our 110" familycar/horsebox hauler/vacation car have been with hoses like that for the last 100k km only problem being me not making "trompets" on the pipeends before fitting the hoses first time around (and even then it took some good 25k km before it blew of one of the hoses). Mads Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted December 27, 2014 Author Share Posted December 27, 2014 Excellent. ... Thanks everyone! ! Quote Link to comment Share on other sites More sharing options...
tacr2man Posted December 27, 2014 Share Posted December 27, 2014 Have been running that set up on my 90 for more than 2 years now , i just doubled up on the hose clips ( no flares ) , and so far no leaks Quote Link to comment Share on other sites More sharing options...
