Repositioning heaterknobs ?
greenstream
If you do have to relocate them, how about to the other side of the instrument pod? You could use simple small pieces of angle to screw tot he side of the pod, securing the top and bottom of the quadrants (the screws you see at the ends of the slot). If you need to cover it up, then you may be able to use the plastic dash end that originally mounted the quadrants or use a sheet of plastic or metal painted with wrinkle paint or Halfords truck bed liner aerosol, which gives a nice texture and is robust.
I used a heater panel from a renault something from a breakers, 2 rotary knobs and fan control. Placed it in a custom centre console.
(Although didnt get around to linking the cables up before selling the 110, as someone here will testify :)
