greenstream Posted February 9, 2015 Share Posted February 9, 2015 Hi Some time a go I saw a picture on the web, showing to relocate the knobs for the heater in a Defender, when installing an internal rollcage. Does any of you know of a clewer sollution to this problem or maybe of said picture ? Morten Quote Link to comment Share on other sites More sharing options...
need4speed Posted February 9, 2015 Share Posted February 9, 2015 Hmmm. This id like to see as i cant think for the life of me where they could neatly go? Quote Link to comment Share on other sites More sharing options...
greenstream Posted February 9, 2015 Author Share Posted February 9, 2015 As I remember from the picture, there they where placed in a small piece of sheetmetal horizontaly in the panel beside the instruments. Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted February 9, 2015 Share Posted February 9, 2015 Hi Morten, unless its a prebuilt cage might I suggest you fit it so close to the windshield/bulkhead that moving the controls are not necessary? My Brother did this when he made his cage, I could snap a picture of it if you'd like? Quote Link to comment Share on other sites More sharing options...
greenstream Posted February 9, 2015 Author Share Posted February 9, 2015 If thats possible, then a picture wouldd be nice. Its a cage we're going to build. Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted February 9, 2015 Share Posted February 9, 2015 Okay, I'll work at getting a picture tomorrow then Quote Link to comment Share on other sites More sharing options...
Snagger Posted February 9, 2015 Share Posted February 9, 2015 If you do have to relocate them, how about to the other side of the instrument pod? You could use simple small pieces of angle to screw tot he side of the pod, securing the top and bottom of the quadrants (the screws you see at the ends of the slot). If you need to cover it up, then you may be able to use the plastic dash end that originally mounted the quadrants or use a sheet of plastic or metal painted with wrinkle paint or Halfords truck bed liner aerosol, which gives a nice texture and is robust. Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted February 10, 2015 Share Posted February 10, 2015 here ya go: Space is tight, real tight. But this is with 50mm tube and as far as I know you usually don't use larger than 45mm? So there should be a little more room for you to play with. Expect some trimming of the door card if your customer is running Defender doors and not Series style Quote Link to comment Share on other sites More sharing options...
greenstream Posted February 10, 2015 Author Share Posted February 10, 2015 Thanks That looks doable. You're right it is a LR with Defender doors, so will have to do some triming. Quote Link to comment Share on other sites More sharing options...
HoSS Posted February 11, 2015 Share Posted February 11, 2015 I used a heater panel from a renault something from a breakers, 2 rotary knobs and fan control. Placed it in a custom centre console. (Although didnt get around to linking the cables up before selling the 110, as someone here will testify Quote Link to comment Share on other sites More sharing options...
