sighnbox Posted February 10, 2015 Share Posted February 10, 2015 Ok guys its been a while but she has been behaving well Ok latest's Landy disaster is .......Get in turn the key and some times nothing the engine does not turn over.........(Not every time) ALL the electrics work fine just no turn over not even a clicking sound.. Ok so rapidly turn the key back and forth and eventually she will start ......usually a slow turn over to start with like its struggling to turn over then will kick in to life ... Now I'm guessing starter obviously but any one think of any other possibilities ??? Quote Link to comment Share on other sites More sharing options...
paulnb57 Posted February 10, 2015 Share Posted February 10, 2015 Yes, it could ge the starter, however it could also be dirty/corroded connections on the starter/battery, so you could clean em up and Vaseline them, could avoid replacing a good starter motor...... Paul Edit, also check the big earth leads that go from battery to chassis and chassis to engine, clean em and Vaseline em!..... Quote Link to comment Share on other sites More sharing options...
rrr47 Posted February 10, 2015 Share Posted February 10, 2015 Could be your ignition switch as well. Quote Link to comment Share on other sites More sharing options...
paulnb57 Posted February 10, 2015 Share Posted February 10, 2015 I wouldn't expect it to turn over slowly if it was the ign switch, The ign switch supplies 12v to the starter solenoid (big relay) the solenoid supplies the major amperage to turn the motor.....hence my though it could be poor connections on the motor/battery/earth.......although I could be wrong!..... Paul Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted February 10, 2015 Share Posted February 10, 2015 Yes, it could ge the starter, however it could also be dirty/corroded connections on the starter/battery, so you could clean em up and Vaseline them, could avoid replacing a good starter motor...... Paul Edit, also check the big earth leads that go from battery to chassis and chassis to engine, clean em and Vaseline em!..... Also check the connections between the end of the earthing straps and the copper cable - these were loosely crimped on then soldered as far as I can tell; after 10 - 15 years the solder fails and the connections are just loosely crimped on. I had exactly this problem on two old 300tdi 90's, in particular the crimp in the middle of the earthing strap off the transfer box and both times the exact symptoms were as you describe. Quote Link to comment Share on other sites More sharing options...
Souster Posted February 10, 2015 Share Posted February 10, 2015 Start with the cheapest first. Clean the main earth points and see how it goes. If no improvement then you'll have to start replacing parts. I wish I had of done this recently and checked the earth's first. Quote Link to comment Share on other sites More sharing options...
sighnbox Posted February 20, 2015 Author Share Posted February 20, 2015 Ok cleaned my bat terminals and earth strap seams to have stoped the slugish start .....started it 15 times jammed onece but prob my fault as started instant turned off before stopped properly so fingers crossed Quote Link to comment Share on other sites More sharing options...
bodumatau Posted February 20, 2015 Share Posted February 20, 2015 sounds familiar, I once "fixed" a land cruiser by shaking it from side to side, this was enough to make contact for a start or two then it would work again. worked fine till could get to a toolbox.... Quote Link to comment Share on other sites More sharing options...
sighnbox Posted February 20, 2015 Author Share Posted February 20, 2015 Been driving it shopping round the city today and lots stops and starts all started ok with no slugish starts ....will see tomorow morning Quote Link to comment Share on other sites More sharing options...
sighnbox Posted February 24, 2015 Author Share Posted February 24, 2015 Was ok a day started again ....new starter arived to day and the dam bolts are SOLID tried all sorts ARRRRRRRRRRRRRR Quote Link to comment Share on other sites More sharing options...
