muddy4x4xfar Posted February 12, 2015 Share Posted February 12, 2015 hi all . does anybody know if it is possible to wire in the radio steering wheel controls to an aftermarket radio. the one I'm fitting is a pioneer. many thanks chris Quote Link to comment Share on other sites More sharing options...
teabag Posted February 12, 2015 Share Posted February 12, 2015 Only if the aftermarket head unit, in your case Pioneer, has the facility to receive the signal from the D2 steering wheel control, if so there are patch leads available to interface the two. Quote Link to comment Share on other sites More sharing options...
Shackleton Posted February 12, 2015 Share Posted February 12, 2015 There are also 'control adapters' available that convert the wheel signals for certain head units. Quote Link to comment Share on other sites More sharing options...
DiscoHere Posted February 19, 2015 Share Posted February 19, 2015 Interesting question and I would be delighted to hear your experience if you go ahead with the conversion. I have been told that the existing head unit is fully amplified throughout the system and not possible to replace. Please prove that wrong as I would love to change my head unit to a more modern one Hugh Quote Link to comment Share on other sites More sharing options...
teabag Posted February 19, 2015 Share Posted February 19, 2015 Some standard high end systems do have an amplifier with the head unit just being the pre-amplifer a D 2 has it under the front passenger seat I believe. There's nothing too stop the fitting of a aftermarket head unit although the installation won't be just plug and play. Quote Link to comment Share on other sites More sharing options...
elbekko Posted February 19, 2015 Share Posted February 19, 2015 Interesting question and I would be delighted to hear your experience if you go ahead with the conversion. I have been told that the existing head unit is fully amplified throughout the system and not possible to replace. Please prove that wrong as I would love to change my head unit to a more modern one Hugh It's possible, but you'll either need a head unit that supplies an unamplified signal, or some electronics to take the buzz out. The CD changer won't work anymore unless the new head unit supports I-Bus. The steering wheel controls can be made to work, there are plenty of converter boxes about, but with a (huge) stroke of luck your head unit will expect the same resistance values as the steering wheel puts out. The resistance values from the D2 RAVE (2003, but probably identical in earlier models): I'd look into Alpine headunits for the best chance of working with the system. Quote Link to comment Share on other sites More sharing options...
