ballcock Posted March 16, 2015 Share Posted March 16, 2015 This may be of interest to you. http://www.ebay.co.uk/itm/Landrover-Defender-Milner-Coversion-From-Tdi-To-V8-With-Sd1-Flywheel-/261814359013?pt=LH_DefaultDomain_3&hash=item3cf55a13e5 Quote Link to comment Share on other sites More sharing options...
need4speed Posted March 16, 2015 Share Posted March 16, 2015 Nice find. Rocking horse poo springs to mind Quote Link to comment Share on other sites More sharing options...
ballcock Posted March 16, 2015 Share Posted March 16, 2015 I was tempted myself. Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted March 17, 2015 Author Share Posted March 17, 2015 I don't want to jinx anything but I think I've found everything I need for a very good price. Thanks though. What is evereyone doing with fuel pumps? Quote Link to comment Share on other sites More sharing options...
need4speed Posted March 17, 2015 Share Posted March 17, 2015 I have TD5 style rear mounted plastic tank. I used an in-tank pump from RR but had to modify a little. I will dig out part number later on. Edit: try and give DaveW a PM. It was he who gave me advice regarding this a few years ago, and if memory serves he sent me some pics of pump modification needed. Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted March 17, 2015 Author Share Posted March 17, 2015 Ok so they can be modded to fit the diesel tank? or just use an inline pump? Quote Link to comment Share on other sites More sharing options...
Ash.Witty Posted March 17, 2015 Share Posted March 17, 2015 When I modified mine, RRC to suit 110 thank, I measured the depth of the tank and the height of the fuel pump. Worked out the difference and fitted a slightly longer section of injector hose to the pump and altered the screw positions of the actual pump. Its easy to work out once you have a pump in front of you. Same bolt pattern as the tank return pipe as well, also pull out the old Tdi pick up pipe and cut the pipe down otherwise the pump strainer will not sit in the very bottom of the tank. Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted March 18, 2015 Author Share Posted March 18, 2015 Ok then, not to difficult. Is it worth fitting genuine or are the pattern ones ok? Quote Link to comment Share on other sites More sharing options...
Ash.Witty Posted March 18, 2015 Share Posted March 18, 2015 I had an Allmakes one, no problem at all. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 19, 2015 Share Posted March 19, 2015 This may be of interest to you. http://www.ebay.co.uk/itm/Landrover-Defender-Milner-Coversion-From-Tdi-To-V8-With-Sd1-Flywheel-/261814359013?pt=LH_DefaultDomain_3&hash=item3cf55a13e5 How does differ from the series to v8 adapter? Isn't the stud pattern the same? Quote Link to comment Share on other sites More sharing options...
ballcock Posted March 19, 2015 Share Posted March 19, 2015 How does differ from the series to v8 adapter? Isn't the stud pattern the same? I believe so, if a 200tdi bolts straight the series box. Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted March 22, 2015 Author Share Posted March 22, 2015 Well I now have most of the things I need, just waiting on mega squirt Quote Link to comment Share on other sites More sharing options...
