dred90 Posted November 8, 2006 Share Posted November 8, 2006 Don't suppose anyone has the above or a description of which coloured wire to which terminal on the back of the starter switch? Quote Link to comment Share on other sites More sharing options...
western Posted November 8, 2006 Share Posted November 8, 2006 (edited) Refer to my diagram in from this thread No connection[at terminal 1, nearest steering wheel] Brown [batt 12v feed to terminal 2 @ 12o'clock position] White [to terminal 3] White/Red [to terminal 4] White/black [to terminal 5] White/orange [not connected as it becomes live -- for accessory/air conditioning-- when ignition switch to position 2 glowplug/pre spring loaded start section of switch] Note -- above info only for a ex-2.5TD engined vehicle that's been converted to a 200Tdi engine. But might be useful for 2.5n/a to 200Tdi if you fit the glowplug timer relay & associated wiring. hope that helps, Edited November 8, 2006 by western Quote Link to comment Share on other sites More sharing options...
dred90 Posted November 8, 2006 Author Share Posted November 8, 2006 cheers western Quote Link to comment Share on other sites More sharing options...
western Posted November 8, 2006 Share Posted November 8, 2006 cheers western Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted May 13, 2008 Share Posted May 13, 2008 Just looking over NAD ex MOD 90 that im getting ready for MOT... Ignition switch was disconnected when I got it... I see western's diagram, but am being stupido... Switch has numbers on the back next to each terminal, and as its not in the vehicle I dont know which is supposed to be where... I have drawn the switch with numbers... Anyone care to put the correct switch numbers to western's diagram? 1 and 5 are the only ones with large terminals, rest are thin... Quote Link to comment Share on other sites More sharing options...
western Posted May 13, 2008 Share Posted May 13, 2008 the thick brown/red is the glow plug feed and on my 110 [ex-TD] was on terminal 1 [large], I don't have any more info for the 2.5n/a ign switch. the switch part should have a indent in the outer edge, the ignition body on the column has a small screw that locates in the indent & therefore orientates the electrical part of the ignition switch. hth Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted May 13, 2008 Share Posted May 13, 2008 Thanks for the quick response, I have redrawn the switch as per your notes, however on my vehicle brown is also a large spade. ON THE SWITCH Terminals 1 and 5 both have big spades...that would put brown with a large female on a small male (oooo err Missus) Should I forget the actual numbers and rotate the switch so that the indent is at a certain position? Quote Link to comment Share on other sites More sharing options...
western Posted May 13, 2008 Share Posted May 13, 2008 Just found this info look at the switch ident 35288, terminals are same as yours & it's a Lucas 128SA, I'm sure that will get you started I thought it was a genuine LR ign switch, didn't realise it's a non LR part. found it here >>> http://www.lucaselectrical.co.uk/technical/SwitchgearTI.pdf Quote Link to comment Share on other sites More sharing options...
tomaco1 Posted June 2, 2009 Share Posted June 2, 2009 Refer to my diagram in from this thread No connection[at terminal 1, nearest steering wheel] Brown [batt 12v feed to terminal 2 @ 12o'clock position] White [to terminal 3] White/Red [to terminal 4] White/black [to terminal 5] White/orange [not connected as it becomes live -- for accessory/air conditioning-- when ignition switch to position 2 glowplug/pre spring loaded start section of switch] Note -- above info only for a ex-2.5TD engined vehicle that's been converted to a 200Tdi engine. But might be useful for 2.5n/a to 200Tdi if you fit the glowplug timer relay & associated wiring. hope that helps, So Nothing on #1? And am confused by the white/orange not being connected? Quote Link to comment Share on other sites More sharing options...
western Posted June 2, 2009 Share Posted June 2, 2009 1 used to be the glowplug feed brown/red thick wires, the white/orange is air con feed if fitted, it becomes live as stated above & I use mine to feed 12v to my rev counter. Quote Link to comment Share on other sites More sharing options...
tomaco1 Posted June 6, 2009 Share Posted June 6, 2009 I have a 4 pin ignition from a 1985 2.5 petrol that had A/C at one point, and am changing to a 5 pin for a diesel 200tdi conversion. what I have: 1)Thick brown 2)big white Brown/orange Small white 3) white/red 4)Brown/Orange I started to just swap numbers to match above, but thinking this is wrong. Pics of the 2 switches side by side, and I hope the 1-5 are clear on the last one. Thanks Quote Link to comment Share on other sites More sharing options...
western Posted June 6, 2009 Share Posted June 6, 2009 what I have:1)Thick brown 2)big white Brown/orange Small white 3) white/red 4)Brown/Orange Brown - from battery to starter soleniod White - 12v feeds [ignition controlled] add the small white here too Brown/Orange trace - to fuse box to supply the green wires White/Red trace - to start relay the actaul tag locations should be on the attachment in my reply above. Quote Link to comment Share on other sites More sharing options...
tomaco1 Posted July 14, 2009 Share Posted July 14, 2009 1 used to be the glowplug feed brown/red thick wires, the white/orange is air con feed if fitted, it becomes live as stated above & I use mine to feed 12v to my rev counter. So if I'm going to use a glowplug, connect it to #1? Quote Link to comment Share on other sites More sharing options...
western Posted July 14, 2009 Share Posted July 14, 2009 Yep Quote Link to comment Share on other sites More sharing options...
tomaco1 Posted July 15, 2009 Share Posted July 15, 2009 Many Thanks Quote Link to comment Share on other sites More sharing options...
dantd5 Posted July 15, 2009 Share Posted July 15, 2009 I have totally made a mess of mine and currently speedo not functioning. Is the wiring the same as a td5 110 99 MY truck? Ignition turns alright but the light systems are jammed! Quote Link to comment Share on other sites More sharing options...
western Posted July 15, 2009 Share Posted July 15, 2009 I have totally made a mess of mine and currently speedo not functioning. Is the wiring the same as a td5 110 99 MY truck? Ignition turns alright but the light systems are jammed! What are you wanting to do Dan ? fit the Td5 instrument pack ? if yes all the wiring info is in the wibbly wobbly speedo thread, most of the wire colour codings match up to the older existing wiring. Quote Link to comment Share on other sites More sharing options...
dantd5 Posted July 16, 2009 Share Posted July 16, 2009 Yes Ralph fit the speedo wiring. I will read the Wobbly thread and make further notice. Thanks!! Quote Link to comment Share on other sites More sharing options...
tomaco1 Posted October 15, 2009 Share Posted October 15, 2009 I finally got around to putting my Ignition switch in, replacing a 4 pin with 5 pin I'm wondering what each wire color I have is for? 1)Thick brown= 2)big white= Brown/orange= Small white= 3) white/red= 4)Brown/Orange= It seems to be working, but I havent hooked up the glow plug timer. It also seems all the terminals are hot when the key is on. I have a 4 pin ignition from a 1985 2.5 petrol that had A/C at one point, and am changing to a 5 pin for a diesel 200tdi conversion. what I have: 1)Thick brown 2)big white Brown/orange Small white 3) white/red 4)Brown/Orange I started to just swap numbers to match above, but thinking this is wrong. Pics of the 2 switches side by side, and I hope the 1-5 are clear on the last one. Thanks Quote Link to comment Share on other sites More sharing options...
western Posted October 16, 2009 Share Posted October 16, 2009 for info & future reference numbers relate to my drawing above ----- No connection[at terminal 1, nearest steering wheel] Brown [batt 12v feed to terminal 2 @ 12o'clock position] White [to terminal 3] White/Red [to terminal 4] White/black [to terminal 5] White/orange [not connected as it becomes live -- for accessory/air conditioning-- when ignition switch to position 2 glowplug/pre spring loaded start section of switch] Note -- above info only for a ex-2.5TD engined vehicle that's been converted to a 200Tdi engine. But might be useful for 2.5n/a to 200Tdi if you fit the glowplug timer relay & associated wiring. from my earlier reply & link above Quote Link to comment Share on other sites More sharing options...
tomaco1 Posted October 17, 2009 Share Posted October 17, 2009 I did follow your previous advice, but i'm still not sure its correct. It may be because I have a newer style 5 pin ignition, but probably its because I'm an idiot. Mine has 4 key positions Off 1 the accessories work 2 nothing happens but one of the unused spades on the back becomes hot, would I have to hold it on position 2 to power the glowplugs? 3 truck starts I'm wondering if this is the way it should be? Thanks I have a 4 pin ignition from a 1985 2.5 petrol that had A/C at one point, and am changing to a 5 pin for a diesel 200tdi conversion. what I have: 1)Thick brown 2)big white Brown/orange Small white 3) white/red 4)Brown/Orange I started to just swap numbers to match above, but thinking this is wrong. Pics of the 2 switches side by side, and I hope the 1-5 are clear on the last one. Thanks Quote Link to comment Share on other sites More sharing options...
western Posted October 18, 2009 Share Posted October 18, 2009 Off 1 the accessories work 2 nothing happens but one of the unused spades on the back becomes hot, would I have to hold it on position 2 to power the glowplugs? 3 truck starts my ign switch is a 5 terminal version too, the terminal 1 is the old TD glowplug connection, you need to leave this disconnected & safely terminated to prevent damage. what you have above looks correct, as the TD glowplugs need the key holding in position prior to starting at pos 2. Quote Link to comment Share on other sites More sharing options...
PieEater3142 Posted March 3, 2012 Share Posted March 3, 2012 After alot of fighting and realising that I have a Lucas 126SA (not the one talked about on here) i found that: 5: Battery 1: Aux 2: Nothing 3: Ign 4: Crank Can anyone else confirm this? Quote Link to comment Share on other sites More sharing options...
Cat_J Posted May 30, 2012 Share Posted May 30, 2012 Hi Yall So I've got most of my wiring back together (also I left it all sitting over winter and a bird built a nest in the dash, incorporating the wiring loom ) Unfortunatly I wasn't the one to pull all the wires off the ignition barrell and have no idea which way round they re attach to the 5 pins. Looks like the original wires so colours should be correct. Anyone have a diagram or some good wisdom? Thanks Quote Link to comment Share on other sites More sharing options...
western Posted May 30, 2012 Share Posted May 30, 2012 this will get you sorted http://forums.lr4x4....i+starter+switc Quote Link to comment Share on other sites More sharing options...
