jeffd Posted May 31, 2015 Share Posted May 31, 2015 A while back I replaced the front discs on my Td5 130 with Paddocks own and the pads with Mintex. Since then I have put up a terrible squealing whilst braking. I have tried the mintex grease for the backs of the pads and copper grease - great for a few miles only. It concerned me that the mintex pads came with no backing or retaining clips (the originals were worn). The paddocks discs now need replacing - any advice on how to avoid the same problem again ? Quote Link to comment Share on other sites More sharing options...
rrr47 Posted May 31, 2015 Share Posted May 31, 2015 Did you bed the pads-in? Are the discs scored or wavy? A cheap solution is to remove the pads and file them flat and try to bed them in again. Quote Link to comment Share on other sites More sharing options...
Mutley Posted May 31, 2015 Share Posted May 31, 2015 Put Mintex discs on rear of the 300tdi 90 last year with no issues came with mintex pads and at a good price too, if that helps? Quote Link to comment Share on other sites More sharing options...
eds Posted May 31, 2015 Share Posted May 31, 2015 Mintex discs and pads work for me too :-) Quote Link to comment Share on other sites More sharing options...
=jon= Posted May 31, 2015 Share Posted May 31, 2015 You can buy the anti-squeal shims separately.. http://www.ebay.co.uk/itm/EBC-ANTI-SQUEAL-SELF-ADHESIVE-BRAKE-PAD-SHIMS-SET-OF-4-LARGE-FITS-ANY-CAR-/291458291665?pt=LH_DefaultDomain_3&hash=item43dc4497d1 I put similar on my Mazda which has race pads fitted (no backing and stupidly noisy compound!) - shut them up totally... Quote Link to comment Share on other sites More sharing options...
jeffd Posted May 31, 2015 Author Share Posted May 31, 2015 Thanks =jon= never seen these before - worth a try. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 31, 2015 Share Posted May 31, 2015 Mintex are OE spec. Excellent quality, durability, and performance. It's unlikely that the discs are the problem as they are just machined cast iron, so anti-squeal shims are probably all you need. Les Quote Link to comment Share on other sites More sharing options...
