Oil leakage at wheels again...
xychix
I've replaced the hub seal as oil was seeping into the drum brakes (front left), now on the same side the swivel seal is leaking :(
Car was parked for a mont and a big stain next to the tyre, as I'm not in the position to redo this for now, I'm lookin for a quick fix.
I'm in the last phase of healing of a broken shoulder blade (Amsterdam, bike crash), driving without PAS is already a challenge, let alone ripping the car apart.
Would it help to add some ATF oil to the 80w90 in the swivel to soften up the seal a bit? Would it do extra damage trying this?
thanks
+1 for one shot grease rather than ep80w90
Edit: and if that's your only leak you are doing well!
Or, its all empty?
haha
gearbox, reductionbox, and engine just mark their spot a bit.
Front axle seems to have a drip hanging but won't call that a leak, rear axle is bone dry... hmm worrying compared to the rest, will check that out.
