reb78 Posted August 16, 2015 Share Posted August 16, 2015 Well, just checking the 110 over as due to take it to Scotland for a fortnight this coming Wednesday and discover a tiny leak on the rad. I bought this unit from M&D engineering in Jan 2013 as an 'uprated four core rad' (http://forums.lr4x4.com/index.php?showtopic=80260&page=2). The leak is coming from a tiny pinprick hole in the solder where the tank on the passenger side is soldered to the frame of the core. I don't really want to risk taking it all that way like this (although it doesn't appear to currently lose much coolant). Given that I would quite like to take it on holiday in two days what would you do. No time to send back to M&D and get it back before Weds (thats assuming they would do anything after 2.5 years), I don't know of any local rad specialists (but I'm sure there are some), or could i clean it up and get the blow torch and solder out?? Other option is forget about it and take the disco, but kinda wanted to take the 110. Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 16, 2015 Author Share Posted August 16, 2015 You can just see a tiny spot of coolant here. There are two dots of solder together at the top and then a third beneath them where there is a tiny dot of coolant Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted August 16, 2015 Share Posted August 16, 2015 I wouldn't risk it, things like this very rarely fix themselves but quite often make themselves worse.. I'd get onto M&D when you get back and see what they say. Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 16, 2015 Author Share Posted August 16, 2015 I wouldn't risk it, things like this very rarely fix themselves but quite often make themselves worse.. I'd get onto M&D when you get back and see what they say. Thanks David. My thoughts really too. I doubt M&D will want to know after 2.5 years, but its leaking at that seam and I would think that should rarely if ever be a failure point (at least, not before the core fins rot away!). I'm going to give a rad place a ring in Hertford first thing in the morning though and see if they can do anything. Stupid really, i should just forget it, but i've spent ages sorting the 110 for this trip and I'm pretty disappointed that its looking like i cant take it. (I only went out to check the oil level in the swivels and as i sat in front of the car, thats what i was met with!) Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 17, 2015 Share Posted August 17, 2015 Add some K-seal to the cooling system. It's perfect for this type of leak and will effect a permanent repair. I've used it many times and it's never failed. Les. Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 17, 2015 Author Share Posted August 17, 2015 Thanks Les. I dont know why, but I am always uneasy with products like K Seal. I rang a localish recore place this morning - I dropped a spare rad off there that needed a recore at 0900 and it was ready for me to collect by 1400 - just going to fit it now. M&D said that their warranty only runs for 12 months from purchase. I kind of get that, but this failure is not because I ran into a tree or even that the fins have rotted with old age (the core is PERFECT) so i kind of felt some sort of goodwill gesture might be in order here. They did say that these types of cracks could occur due to insufficient isolation of the rad (i.e. failed rubber mounts), but they are all in good order on mine and i even have an old rubber bike inner tube that isolates the rad from the intercooler next to it! Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted August 17, 2015 Share Posted August 17, 2015 I'd say that's far from brilliant from M&D imho.... Still at least your sorted now. How much was the recore of the standard rad Richard? Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 17, 2015 Author Share Posted August 17, 2015 £175 Dave, so about as much as a new metal rad can be had for. Even if it's a bit more he turned it round so quickly it was worth it. The M&D one will be going to him for repair. I wasn't really impressed with their response. All fitted now. Discovered I need a new fan belt now though!! Will it ever end!! Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted August 17, 2015 Share Posted August 17, 2015 Reason I asked is the old TD rads only come from Brittlepart now apparently.... My 110 needs another fan belt, it does eat them for some reason and so does the Disco. Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 17, 2015 Author Share Posted August 17, 2015 It's hard to find metal rads now, so having two (once this one is repaired) seems a good move! He's done a nice job so if you can get yours done, that's a good way to go I suppose. One thing I would say, at nearly £100 more, the m&d one wasn't worth it with a 2.5 year lifetime! Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted August 17, 2015 Share Posted August 17, 2015 No it doesn't seem like money well spent to be honest with you. I would think your leak was nothing short of bad luck but I would still expect them to sort it out for little or no charge. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 17, 2015 Share Posted August 17, 2015 If its any use, I've got an old TD rad I think it is kicking around the workshop Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted August 18, 2015 Share Posted August 18, 2015 I'm OK at the minute, I'm thinking more when it goes wrong.. Thanks anyway. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted September 6, 2015 Share Posted September 6, 2015 It's hard to find metal rads now, so having two (once this one is repaired) seems a good move! He's done a nice job so if you can get yours done, that's a good way to go I suppose. One thing I would say, at nearly £100 more, the m&d one wasn't worth it with a 2.5 year lifetime! Although the warranty is 1 year you may still have some power here because products are expected too have a reasonable lifespan. This can be up to 6 years for certain products, I don't know what it would be on car parts. I do believe that it is up to you to prove it's a manufacturing problem rather than abuse. Quote Link to comment Share on other sites More sharing options...
reb78 Posted September 6, 2015 Author Share Posted September 6, 2015 Thanks Barry. If they were local I would have been round there with it. Trouble is they are over 100miles away and trying to have this argument from a distance will be a major pain! I only went this way because it seemed like a worthwhile upgrade, so I'm a bit gutted really. Hopefully the chap who recored my other rad as a result of this will be able to repair this one for not too much. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted September 6, 2015 Share Posted September 6, 2015 I understand perfectly where you are coming from, and there's a lot to be said for avoiding the argument/stress. Quote Link to comment Share on other sites More sharing options...
