dantastic Posted January 4, 2016 Share Posted January 4, 2016 We are using Motorola T80 walkie talkies. They are not loud enough inside a Defender. Do anyone know of any external loudspeaker that can be used in conjunction with walkie talkies. I need to be able to talk as well so I think it may need a microphone or else any plugged in loudspeaker will make it a listen only jobby. (single pin system) Quote Link to comment Share on other sites More sharing options...
Arjan Posted January 4, 2016 Share Posted January 4, 2016 Several options here : "Security Covert Walkie Talkie Handsfree Headset MOTOROLA TLKR T60 T80 XTB446" type earpieces & mic. or "Military Throat Mic Headset/Earpiece For Motorola Radio TLKR T60 T80 XTB446 1PIN" Basically, most 1 pin things will work. Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted January 4, 2016 Share Posted January 4, 2016 we have icom units at work which have a lapel mic/speaker as an extra. Can you get something like that for yours? Quote Link to comment Share on other sites More sharing options...
dantastic Posted January 4, 2016 Author Share Posted January 4, 2016 Something like this? http://www.icomuk.co.uk/categoryRender.asp?categoryID=3761&productID=1223&tID=938 I think that will make it listen-only. I have both the regular headset that comes with the units and we tried the throat mics as well. The headset which comes with the unit is not loud enough either. It's pretty poor to be honest. The throat mic works well but is quite uncomfortable. I can't get used to it... Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted January 4, 2016 Share Posted January 4, 2016 no, you can talk and listen, like this, see the 2 plugs on the 1 moulding for the speaker & mic; Our guys wear the radio on a belt and have the mic clipped on a top pocket or jacket lapel and they can communicate when driving the forklifts or standing around the machines. http://www.icomuk.co.uk/categoryRender.asp?categoryID=3759&productID=1171&tID=938 You can also get a headset that activate when you start to talk but I find them too sensitive in a working environment. Quote Link to comment Share on other sites More sharing options...
dantastic Posted January 4, 2016 Author Share Posted January 4, 2016 That's a 2 pin system. The Motorolas only have a single pin you see.. Quote Link to comment Share on other sites More sharing options...
Arjan Posted January 4, 2016 Share Posted January 4, 2016 Yes - but they will take the combined speaker / mic ext. sets. Quote Link to comment Share on other sites More sharing options...
dantastic Posted January 4, 2016 Author Share Posted January 4, 2016 I might try one so if you think it will work. My worry is it will be listen only and the built-in mic won't work with something plugged in to the jack. Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted January 4, 2016 Share Posted January 4, 2016 http://radios-uk.com/tlkrt5accessories.htm Will do what you want Quote Link to comment Share on other sites More sharing options...
dantastic Posted January 4, 2016 Author Share Posted January 4, 2016 http://radios-uk.com/tlkrt5accessories.htm Will do what you want Are they any louder though? Quote Link to comment Share on other sites More sharing options...
