ronnie_rotten Posted January 12, 2016 Share Posted January 12, 2016 Ok. Another day, another question! When I turned off the Disco earlier what I assume was the compressor made a slightly unhappy sounding grumble. It lasted about a second, stopped for 2 or 3 seconds and grumbled again. It did this 2 or 3 times. Thoughts? Quote Link to comment Share on other sites More sharing options...
Boydie Posted January 12, 2016 Share Posted January 12, 2016 "Assume" makes an ass out of U and me. Lift the bonnet and get you wife/GF/mate/neighbour to turn the motor off while you are observing and listening. You should get a clearer idea of where the sound is coming from, it may take a couple of attempts to track it down but it's a far better method that trying to trace it from the drivers seat. My 'umble guess - I think it's more likely to be a very dry/stuffed electric fan bearing rumbling until the fan blades stop turning. The A/C compressor will cease to rotate the moment the engine stops turning. It could also be the mechanical thermal fan that needs to be replaced. Quote Link to comment Share on other sites More sharing options...
Boydie Posted January 12, 2016 Share Posted January 12, 2016 Just a second thought, it could be steam gurgling up into the header tank, you may have a minute head gasket leak - like a volcano, tiny rumbles of steam are often a warning of worse things to come. If it is, check all aspects of your cooling system first, levels, air locks, circulation, pump, thermostat, coolant leaks etc. etc. etc. BEFORE you resort to replacing the head gasket. Quote Link to comment Share on other sites More sharing options...
ronnie_rotten Posted January 13, 2016 Author Share Posted January 13, 2016 Hmmm. The spund happend maybe 5 sdconds after i got oit of the car and started walkng away. I'm thinking nothing to do with cooling system. Thankfully. It was the kind of noise a crappy argos electric tyre pump makes so I'm going to stick with my donkey's guess that it was the compressor firing up for some reason. Will the SLS system still do it's thing after the engine is switched off? Where I parked it isn't pool table flat. Might this be a sign that there's a slow leak in one of the air springs and the sls is trying to work after hours? Not too uncommon fir the bags to perish i understand? Quote Link to comment Share on other sites More sharing options...
Pawl12 Posted January 13, 2016 Share Posted January 13, 2016 Is it from under the car (eg sls compressor) or engine bay? If engine bay, I've heard there are abs faults which can cause the abs modulator valves to "chatter" after switching off. Quote Link to comment Share on other sites More sharing options...
bear Posted January 13, 2016 Share Posted January 13, 2016 It's not by any chance the "Disco Fart" caused when the SLS lets out air to level itself. just a thought, Griff Quote Link to comment Share on other sites More sharing options...
ronnie_rotten Posted January 13, 2016 Author Share Posted January 13, 2016 It's not by any chance the "Disco Fart" caused when the SLS lets out air to level itself. just a thought, Griff I think I'm happy to accept your diagnosis. Not least so I can tell the missus that's what it when she hears it for the first time. It's definitely coming from underneath and not under the bonnet. Disco fart. An all too common occurrence among air sprung land rover owners. Quote Link to comment Share on other sites More sharing options...
IanS Posted January 14, 2016 Share Posted January 14, 2016 There's that (which I prefer to call a sigh of relief), but also the compressor quite often runs a couple of times after you've switched off. Nothing to worry about. Quote Link to comment Share on other sites More sharing options...
ronnie_rotten Posted January 14, 2016 Author Share Posted January 14, 2016 Then I'll worry no more. Cheers. Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted January 15, 2016 Share Posted January 15, 2016 Will always do this once all the doors are closed and the engine is off - if it doesn't then you know its a new compressor. There is a factory issue inlet now available to avoid the water ingress issue with he compressor - about 70 quid but worth a punt Don't forget you will get the centrifugal oil filter spinning for a while after shut down Quote Link to comment Share on other sites More sharing options...
IanS Posted January 15, 2016 Share Posted January 15, 2016 BUT - one day I got out of mine and I could hear the compressor running continuously. After investigating it turned out the relay points had welded themselves together. A quick swap for the headlight wash relay and all was well. Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted January 15, 2016 Share Posted January 15, 2016 yup... I've fitted two compressors this year... Quote Link to comment Share on other sites More sharing options...
