V8 Plenum Throttle Assembly
Are there different types?
The reason I ask is that FINALLY I've got my hands on a genuine V8 air box (thanks Nige)..
However as can be seen in the pics below, the grubbins on my assembly makes it very awkward to fit the AFM / hoses between air box and plenum.
Compared to
http://forums.lr4x4.com/index.php?showtopic=15317#
The AFM for MS is just a temp sensor. You could make it all out of stainless sections and weld the boss in where ever you want.
Edit: I think I can see your problem, are you using a short bellhousing? Because it looks like the one in the bottom pic is using a long one giving more room between the bulkhead and plenum
