need4speed Posted February 18, 2016 Share Posted February 18, 2016 Are there different types? The reason I ask is that FINALLY I've got my hands on a genuine V8 air box (thanks Nige).. However as can be seen in the pics below, the grubbins on my assembly makes it very awkward to fit the AFM / hoses between air box and plenum. Compared to http://forums.lr4x4.com/index.php?showtopic=15317# Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 18, 2016 Share Posted February 18, 2016 That rubbery thing is a "Drain" and should be at the bottom Nige Quote Link to comment Share on other sites More sharing options...
need4speed Posted February 18, 2016 Author Share Posted February 18, 2016 Ok but that isn't really my issue.. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 18, 2016 Share Posted February 18, 2016 Are you looking to retain the cruise control? Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted February 18, 2016 Share Posted February 18, 2016 The AFM for MS is just a temp sensor. You could make it all out of stainless sections and weld the boss in where ever you want. Edit: I think I can see your problem, are you using a short bellhousing? Because it looks like the one in the bottom pic is using a long one giving more room between the bulkhead and plenum Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 18, 2016 Share Posted February 18, 2016 You could always turn the plenum round... Quote Link to comment Share on other sites More sharing options...
need4speed Posted February 18, 2016 Author Share Posted February 18, 2016 Cruise control? God no lol! Is that what all that carp is? Doug no it's normal bellhousing. Maybe just the pics making it look like that? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 18, 2016 Share Posted February 18, 2016 Take the cruise control bell puffer thing off ? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 18, 2016 Share Posted February 18, 2016 Yep, all that cruft around the bellows/actuator is for the cruise control... with that gone it will make life a LOT easier I feel... Quote Link to comment Share on other sites More sharing options...
need4speed Posted February 18, 2016 Author Share Posted February 18, 2016 So I take it the only stuff I need there is just the throttle cable itself? That will certainly help. Thanks guys.. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 18, 2016 Share Posted February 18, 2016 Yep, and as you are manual, there's not even a kickdown cable to get in the way... You might want a couple of return springs as well though Quote Link to comment Share on other sites More sharing options...
need4speed Posted February 18, 2016 Author Share Posted February 18, 2016 Thanks Bowie Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted February 18, 2016 Share Posted February 18, 2016 Part of the issue might be that as far as I'm aware, they didn't fit that type of airbox on an injection v8 in a defender. .... so you have a mismash of bits.... Quote Link to comment Share on other sites More sharing options...
Aragorn Posted February 19, 2016 Share Posted February 19, 2016 the factory V8's had a pipe that dropped down and back up to avoid that gubbins: http://defender50th.co.uk/GB%20002%20pics/my%20V8.jpg Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 19, 2016 Share Posted February 19, 2016 Yeah, and an air filter intake right above the exhaust manifold(!) Quote Link to comment Share on other sites More sharing options...
Aragorn Posted February 19, 2016 Share Posted February 19, 2016 heh, yeh, and that filter intake looks ludicrously small too. Why not just duct it to the wing vent like the TDI models? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 19, 2016 Share Posted February 19, 2016 Parts bin special -it is an RRC V8 EFI filter housing. ...and ducting costs money, and no left over parts they could borrow that would do the job Quote Link to comment Share on other sites More sharing options...
