JMZ153 Posted February 23, 2016 Share Posted February 23, 2016 So I've just put a 300tdi and r380 into my 90.. Started it today and bled clutch. Tried to drive the Landy and clutch doesn't have much travel down, when engaging gear with clutch pressed the 90 does move slightly as if it's hitting the biting point. Reverse gear is also very difficult to engage.. Any idea what it could be? Setting? Clutch? Clutch not bled properly?? Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted February 23, 2016 Share Posted February 23, 2016 Check the pedal height is correct. If that's OK, there's probably still air in there. Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted February 23, 2016 Share Posted February 23, 2016 If that fails, did the slave cylinder come with the gearbox or is it new? There are 2 for the R380 and has to be matched to the push rod length: http://forums.lr4x4.com/index.php?showtopic=11898 Quote Link to comment Share on other sites More sharing options...
Boydie Posted February 24, 2016 Share Posted February 24, 2016 I'll go with the sleaze on this, my guess is you have the shorter of the two push rods, either that or the rod has come out of the clamp (of the urine weak design) holding it into the clutch lever cup. Quote Link to comment Share on other sites More sharing options...
simonb Posted February 24, 2016 Share Posted February 24, 2016 Reset the pedal height and the pushrod free play on the master. The details are on here, or someone will no doubt post a clicky linky for you. Quote Link to comment Share on other sites More sharing options...
western Posted February 24, 2016 Share Posted February 24, 2016 Reset the pedal height and the pushrod free play on the master. The details are on here, or someone will no doubt post a clicky linky for you. Adjustment info in http://forums.lr4x4.com/index.php?showtopic=81980 always do this after any clutch work. Quote Link to comment Share on other sites More sharing options...
JMZ153 Posted February 28, 2016 Author Share Posted February 28, 2016 Thanks to everyone who replied.. Culprit was pedal adjustment.. Adjusted it again and works like a dream.. everything was new (clutch, slave, master).. Thanks again 1 Quote Link to comment Share on other sites More sharing options...
