Hybrid_From_Hell Posted November 23, 2006 Share Posted November 23, 2006 Hi all, Most of the industrial press brakes are HUGE, but taklking a while back to Paul W he did confirm that there are some press brakes that are say a 1 metre bed rather than the "Normal" 3 metre etc. Anyone know makes models or where maybe from S/H tool shops etc. Been hunting but not found anything so far ? Nige Quote Link to comment Share on other sites More sharing options...
Lewis Posted November 23, 2006 Share Posted November 23, 2006 Is a Press-brake a guilotine, or do i not know what i'm on about? as per Lewis Quote Link to comment Share on other sites More sharing options...
Mark Posted November 23, 2006 Share Posted November 23, 2006 It's like a big powered folder, rather than a guillotine... Quote Link to comment Share on other sites More sharing options...
Lewis Posted November 23, 2006 Share Posted November 23, 2006 It's like a big powered folder, rather than a guillotine... Well in that case i kinda know what i'm on about At work there are various folders in diffrent departments, ranging from a rather tasty 3metre hydraulic jobbie that can manage 10mm plate (probably bigger too but 10mm is the thickest we have), to rather small 1 meter manual machines that can do 2-3mm steel max or upto around 5mm ali - I have tired to bend thicker stuff with these but due to not being able lower the folding edge enough it just tends to shear it Gone slightly OT their, if you want recommendations of which manufacturers are best IMHO then i'll have a look at work on monday (cant remember of the top of my head) Lewis Quote Link to comment Share on other sites More sharing options...
dollythelw Posted November 23, 2006 Share Posted November 23, 2006 how thick do you want to fold Nige? Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted November 24, 2006 Share Posted November 24, 2006 Uh oh... Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 24, 2006 Share Posted November 24, 2006 promecam or edwards pearson are about the best imho, we've got a 3m and 1.5m at my works, i'll ask around about sourcing s/hand ones. i take it u'd want a manual one rather than cnc? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 24, 2006 Author Share Posted November 24, 2006 PMSL at Turbochargers comment Ok I would like one that will bend say 6mm, with a 1 metre(ish) bed, and nope, CNC I am not wantingr or NC - I'd prefer the old fashioned BMBMTWD system (Bit more bit more that willdooooo ) I know chances of single phase is slim, but inverter can be got, and my mates has both leccy and an air line going to it - not sure why, or how that works, but again not a problem... Keep the info coming Nige Quote Link to comment Share on other sites More sharing options...
missingsid Posted November 24, 2006 Share Posted November 24, 2006 Well in that case i kinda know what i'm on about At work there are various folders in diffrent departments, ranging from a rather tasty 3metre hydraulic jobbie that can manage 10mm plate (probably bigger too but 10mm is the thickest we have), to rather small 1 meter manual machines that can do 2-3mm steel max or upto around 5mm ali - I have tired to bend thicker stuff with these but due to not being able lower the folding edge enough it just tends to shear it Gone slightly OT their, if you want recommendations of which manufacturers are best IMHO then i'll have a look at work on monday (cant remember of the top of my head) Lewis Still slightly OT If you want to lower the folding edge, can't you add another slice of sheet below the one you want to bend as a packing peice? This would raise the folded sheet with the same effect. You could alter the thickness of the packing to suit the difference in hieght required. The main problem that I have seen with manual folders is that the clamping fingers are not strong enough for thicker sheet. Quote Link to comment Share on other sites More sharing options...
