geoffbeaumont Posted April 23, 2016 Share Posted April 23, 2016 Helping a friend fit new suspension bushes to his J reg 110 - we're puzzled by the rear trailing arms. At the chassis end the kit he's bought (it's a super pro poly kit) has two large washers and an inner steel tube per side. However, the tube and washers are too small to fit beyond the threaded part of the arm, so only the outer washer can be fitted. The arm has a disk at the other end of the bush, and that and the non-threaded section within the bush look to be part of the arm not removable. The bush is a bit loose without the inner tube. Can anyone shed any light? Quote Link to comment Share on other sites More sharing options...
western Posted April 23, 2016 Share Posted April 23, 2016 the centre tube & both end washers are part of the bush assembly, one genuine bushes these are all one piece http://www.allbrit.de/UNI.cfm?PAGE=756230&SPRACHE=EN Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted April 23, 2016 Author Share Posted April 23, 2016 Like I said, these are super pro bushes not standard. That makes me think there might be a washer and tube solidly rusted onto the arm, though. Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted April 23, 2016 Share Posted April 23, 2016 would this help give a size reference of what they should look like? you can compare to see if yours have a seized sleeve against the pics in the link? http://forums.lr4x4.com/index.php?showtopic=24774 of perhaps you have ordered worng item? i know later arms are wider at axle end, maybe LR also changed chassis end?? Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted April 23, 2016 Author Share Posted April 23, 2016 That definitely looks like we've got bits of an old bush on there. 1 Quote Link to comment Share on other sites More sharing options...
western Posted April 23, 2016 Share Posted April 23, 2016 getthe BFH out to play & give the stuck washer a good wallop, probably just stuck with rust, my new Superpro bushes are waiting to be fitted to my 110, the 2 end washers are seperate as is the inner tube. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 23, 2016 Share Posted April 23, 2016 As above, there's no disc fixed to the arm... Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted April 23, 2016 Author Share Posted April 23, 2016 A good deal of heat (yeah, I know - it wouldn't budge any other way) and hammering later, it's off. Now just got to get the nut off on the other side... Cheers Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted April 23, 2016 Author Share Posted April 23, 2016 Gave up on the seized nut and left that arm alone for now - Sam needed the truck back on the road and we were running out of time. In any case the rear bushes were nowhere near as bad as the front - some of those had basically disintegrated, leading to some deeply scary handling! The truck is predictably transformed. Quote Link to comment Share on other sites More sharing options...
western Posted April 23, 2016 Share Posted April 23, 2016 spray the other trailing arm nut with a good shot of Plusgas, it works for me. Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted April 23, 2016 Author Share Posted April 23, 2016 It has been - only over the last 24hrs though so maybe a little more time well help. Judging by the state of some of the bearings it's been on there a fair time, though. 1 Quote Link to comment Share on other sites More sharing options...
