Ensuring that number 1 piston is at TDC
How do you do that then ?
  • Please log in to reply
8 replies to this topic
#1 cypermethrin
cypermethrin
    Old Hand
  • Settled In
  • PipPipPip
  • 218 posts
Posted 09 December 2011 - 11:53 AM
I need to replace the gasket in my 300TDi brake servo vacuum pump.
Step 1 of this according to the 300TDi "Engine Overhaul manual" says " Ensure that number 1 piston is at TDC" then unbolt etc etc
Given that I only want to chnage the gasket and not take the head off - how can I do this ?? Or do it not need to !
Thanks
Land Rover Defender 90 300TDi
#2 cypermethrin
cypermethrin
    Old Hand
  • Settled In
  • PipPipPip
  • 218 posts
Posted 09 December 2011 - 12:50 PM
OK so you peek in thro' the wading hole and look for the gap which marks TDC of piston 1
I understand there are two such holes in the flywheel (one small and one 3x ish bigger) - how do you know you have the right one ?
#3 plasticbadger
plasticbadger
    Old Hand
  • Supporters
  • 887 posts
Posted 09 December 2011 - 12:55 PM
A double check and some what better in that it confirms that you are both at TDC on number one and on the compression stroke, is as follows:
Remove the glow plug from no.1 cylinder.
Push some rolled up paper towel into the glow plug hole.
Turn the crank until the paper towel pops out, hitting you in the eye and permenantly blinding you.
You should then find you are at or around one of the holes in the flywheel. If not you can GENTLY insert a screw driver or simlilar into the glowplug hole and continue to turn the crank, CAREFULLY making sure the screw driver doesn't bind up, until the screw driver goes up and then starts to go down again on the piston stroke.
2015 Ford Ranger / 2003 Disco V8 / 1993 Toyota Lancruiser 80
www.facebook.com/mooseoffroaduk
#4 Landy-Novice
Landy-Novice
  • Supporters
  • 1,789 posts
Posted 09 December 2011 - 03:13 PM
thats how i got taught to do it but using the dipstick,. :)
#5 western
western
    Recovery Man
  • Moderators
  • 31,228 posts
Posted 09 December 2011 - 06:47 PM
I didn't when I did the same job on my 200tdi, just don;t move the Vac pump shaft or internals, it'll fit back in the same place, hasn't caused any problem on my 17 year old engine.
Ralph, M3WRM, MSA Recovery Operator -- Western Recovery [Motorsport] http://www.amro.org.uk/
Defender Forum Moderator
Keep LR4x4.com Independent -- you can help by Clicking Here
#6 mmgemini
mmgemini
    Old Hand
  • Settled In
  • PipPipPip
  • 4,414 posts
Posted 09 December 2011 - 07:13 PM
What's wrong with taking the oil filler cap off and watching the rockers ?
mike
Quis custodiet ipsos custodes?
I can cause trouble in an empty house !
#7 plasticbadger
plasticbadger
    Old Hand
  • Supporters
  • 887 posts
Posted 10 December 2011 - 02:10 PM
That will only tell you roughly that you're at TDC, unless you know how many degrees before TDC both valves closed and the cam timing compared to crank.
#8 mmgemini
mmgemini
    Old Hand
  • Settled In
  • PipPipPip
  • 4,414 posts
Posted 10 December 2011 - 02:54 PM
So is fitting the vacc pump THAT accurate on the TDC ?
mike
#9 RedLineMike
RedLineMike
    Only mildly Xtreme Anorak
  • Settled In
  • PipPipPip
  • 885 posts
Posted 10 December 2011 - 08:04 PM
on a 300tdi ive never bothered with worrying about if cylinder 1 is at tdc, unbolt vacum pump & refit as required
www.allisport.com
www.bellautoservices.co.uk
www.megasquirt-v8.co.uk
