Cchase Posted January 24, 2017 Share Posted January 24, 2017 Is there an easy way to bump over the engine from the engine bay when adjusting the valves? With the starter relay inside, is there a safe way to bridge the starter? Thanks, Colin Quote Link to comment Share on other sites More sharing options...
Kevm Posted January 24, 2017 Share Posted January 24, 2017 Why don't you just get a big socket to fit the crank pulley nut and then you can turn it slowly by hand. Have you ordered injector washers yet? Mine arrived but not sure they are right yet. Kev Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 24, 2017 Share Posted January 24, 2017 Socket on the crank, not hard to do, especially if you do it slowly and/or have the plugs out. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted January 24, 2017 Share Posted January 24, 2017 Just remember to take the socket/wrench off the crank before starting the engine afterwards 2 Quote Link to comment Share on other sites More sharing options...
Cchase Posted January 24, 2017 Author Share Posted January 24, 2017 Kev, Ordered the washers and they were dispatched today. It was snowing on Sunday so I didn't get much time to look at the old washers...providing that they are there. Thanks all for your replies. I guess that this is an obvious solution. I use a remote starter on my MGB because I cannot get a socket easily on the crank pulley nut. James: That sounds like great advice with a bit of a back story?! Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted January 24, 2017 Share Posted January 24, 2017 As my driveway is more or less level, I put it in third gear, and rock the car forward to turn the engine Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted January 24, 2017 Share Posted January 24, 2017 Err, yes. A big bang/clatter, two seconds of "what the f... has happened to my engine!?", then realisation dawns. Took a chunk out of the fan cowl though! Another method is to jack up a front wheel and turn it with the car in the appropriate gear, which will turn the engine over. Quote Link to comment Share on other sites More sharing options...
Cchase Posted January 24, 2017 Author Share Posted January 24, 2017 Oops! Stories like that are yet another reason why it is more fun to work on your own truck rather than have someone else do the work! Quote Link to comment Share on other sites More sharing options...
neil110 Posted January 29, 2017 Share Posted January 29, 2017 On mine, when I had a 300tdi and left the socket on the end of the crank, fortunately it was a ratchet so didn't spin the entire assembly until it hit something solid but I wondered what the new noise was. Or when I had a Laverda Jota and fired that up, the blast from the exhaust sent the dustbin flying, from inside a helmet it sounded like the bottom of the engine had just fallen out. Quote Link to comment Share on other sites More sharing options...
Cchase Posted January 29, 2017 Author Share Posted January 29, 2017 Just got a 41mm socket ($9.95) and with the injectors out the engine is easy to spin. I am using the breaker bar to rotate the socket - I cannot close the bonnet with it still attached. : ) Quote Link to comment Share on other sites More sharing options...
