TheRecklessEngineer Posted January 19, 2008 Share Posted January 19, 2008 Driving home last night and noticed the oil light start flickering as I go round corners. Pull over and check oil level.....bugger....off the bottom of the dipstick....and none spare in the car. Limp along for a little bit going round corners slowly, but only manage a few miles before giving up and phoning a mate to bring some out to me. It takes about 4 litres before it hits the low mark on the dipstick. So....what damage have I done by running for a few seconds without oil pressure/running with <2 litres of oil in the system? Luckily, I know the oil is disappearing out of the rear crank oil seal....however it seems to be getting much worse. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted January 19, 2008 Share Posted January 19, 2008 If it is not knocking now hopefully you caught it in time. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted January 19, 2008 Author Share Posted January 19, 2008 Thanks...just what I wanted to hear! Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 19, 2008 Share Posted January 19, 2008 You should have got your mate to bring a longer dipstick, the problem would disappear and you wouldn't have had to buy expensive oil. Les. For those that think I'm serious - forget it! Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted January 19, 2008 Author Share Posted January 19, 2008 Funny you should say that...he turned up with 5 litres of GTX magnatec! Needless to say ill be doing an oil change fairly shortly...can't have rubbish like that in my sump. :D Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted January 20, 2008 Share Posted January 20, 2008 dont worry....... sounds like it wont be in your sump for long mike Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 20, 2008 Share Posted January 20, 2008 It's not the engine damage you need to worry about, it's the damage Jen will do to you for neglecting Bob! If it didn't make any nasty noises you are probably OK. Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted January 20, 2008 Share Posted January 20, 2008 May make the rear oil seal a bit worse, but it sounds like your be ok this time. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted January 21, 2008 Author Share Posted January 21, 2008 Lost another 3 litres or so in the last 200 miles (I checked it this time rather than relying on warning lights). A quick look in daylight reveals that when I changed the vacuum pump I accidentally sandwiched a bracket between the pump and the block, creating a nice little gap for the oil to escape. 10 mins later and its all sorted. What a blunder! Quote Link to comment Share on other sites More sharing options...
ChrisV8 Posted January 21, 2008 Share Posted January 21, 2008 and the bikers who fall off on the oil slick will not be happy bunnies either Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 21, 2008 Share Posted January 21, 2008 and the bikers who fall off on the oil slick will not be happy bunnies either If they will tear about dressed as power-rangers with the wrong number of wheels Quote Link to comment Share on other sites More sharing options...
MECCANO Posted January 22, 2008 Share Posted January 22, 2008 and the bikers who fall off on the oil slick will not be happy bunnies either But its okay for mopeds to blow the carp out of the exhaust Quote Link to comment Share on other sites More sharing options...
