atj001 Posted November 15, 2009 Share Posted November 15, 2009 hi every one, can any of you tell me if i can tweak my 200tdi pump for some more power. and if so how to do it??? many thanks everyone Quote Link to comment Share on other sites More sharing options...
western Posted November 15, 2009 Share Posted November 15, 2009 all you need to know http://forums.lr4x4.com/index.php?showtopic=31 Quote Link to comment Share on other sites More sharing options...
reb78 Posted November 15, 2009 Share Posted November 15, 2009 Ralph, Is there any way of getting the pics up again on that link? Dont know if it is possible or not. Quote Link to comment Share on other sites More sharing options...
western Posted November 15, 2009 Share Posted November 15, 2009 probably unlikely as IIRC it was saved from the old [now defunct LRE forum] this is another version, don't know about photo's on this one http://www.landroveraddict.com/smf/index.php?topic=91564.0 Quote Link to comment Share on other sites More sharing options...
reb78 Posted November 15, 2009 Share Posted November 15, 2009 probably unlikely as IIRC it was saved from the old [now defunct LRE forum] this is another version, don't know about photo's on this one http://www.landroveraddict.com/smf/index.php?topic=91564.0 I thought that might be the case. I have registered on the other link and will have a look there. Thanks Quote Link to comment Share on other sites More sharing options...
FLASH Posted November 15, 2009 Share Posted November 15, 2009 You might want to consider the fuel consumption before you tweek it my 200 is tweeked a little plus an allisport intercooler and I am getting between 11 to the gallon on a bad day and 17 on a good one Quote Link to comment Share on other sites More sharing options...
zoltan Posted November 15, 2009 Share Posted November 15, 2009 Eek, you might as well tweak it into a V8 once it gets down that low Quote Link to comment Share on other sites More sharing options...
reb78 Posted November 15, 2009 Share Posted November 15, 2009 You might want to consider the fuel consumption before you tweek it my 200 is tweeked a little plus an allisport intercooler and I am getting between 11 to the gallon on a bad day and 17 on a good one Are you sure its not tweaked too much?! Turn the pump back a bit... Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted November 15, 2009 Share Posted November 15, 2009 This is the direct link to a very comprehensive guide I have used in the past (apologies if it is linked to in any of the above forums!) http://dodgeram.org/tech/dsl/more_power/Power_ve.htm Quote Link to comment Share on other sites More sharing options...
RILEY Posted November 15, 2009 Share Posted November 15, 2009 Tweeked my pump 300tdi defender only gettin about 15 mpg fast as fook tho no only jokin not driven bad still only about 15 tho no not tweeked wrong niether probably the m/t tyres Quote Link to comment Share on other sites More sharing options...
Megansfolly Posted November 16, 2009 Share Posted November 16, 2009 u have well over tweeked the pump i did mine and was getting 8-11mpg i ve now turned it back a bit and back to 27+ on arun Quote Link to comment Share on other sites More sharing options...
reb78 Posted November 16, 2009 Share Posted November 16, 2009 u have well over tweeked the pump i did mine and was getting 8-11mpg i ve now turned it back a bit and back to 27+ on arun How much would you reccomend turning from standard - i.e. what did you end up with in the end roughly? Did you just turn the diaphragm or do the starwheel and smoke adjustments as well? Oh - and was your speedo reading in your avatar a result of the tweak?! Quote Link to comment Share on other sites More sharing options...
