Dual Battery volt guage
You can monitor two batteries with one gauge by using a switch and a change over relay.
It will obviously only display one battery at a time, you flick the switch to swap between batteries, but I used this method without problems when I had a split charge system.
Minimal cost option.
I was going to say just switch it like Pat says,  saves gauge space and pretty easy to do.
I remember the original land rover twin fuel rank setup used a switch relay on the dial to allow you to see what you had in each tank...  similar system.
I've used a few of these:
http://www.sparkbright.co.uk/sparkright-eclipse-battery-voltage-monitor.php
and
For multi-battery monitoring.  They work really well - and give you all the information you actually need, without having to read a dial.
Si
  • Like 1
Hi
Thanks for that
 like Simonrs the little Eclipse things - neat idea and compact. plus i think light changes more liley to be quickley noticed that a "steady" guage if you are a dozy old git like me
I had been thinking about 2 of the rectangle jobbies or the alternative little round jobs also on e bay and like Roverdrive pondering the best layout for dash/Raptor console
