BogMonster Posted September 14, 2005 Share Posted September 14, 2005 New winch for you Nige In case the one you have isn't enough here is its big brother - even has a pneumatic freespool already fitted I reckon you could make it fit though you'd need some 110 rear springs on the front 41ft/min with 10 Land Rovers chained to the back Quote Link to comment Share on other sites More sharing options...
Tonk Posted September 14, 2005 Share Posted September 14, 2005 Nige would have to beef it up a bit to move his lardy @rse or his truck my turn to run Quote Link to comment Share on other sites More sharing options...
wettstuff Posted September 14, 2005 Share Posted September 14, 2005 Only 50m of 20mm wire though. Even the wire is up to nige's minimum material thickness Mark Quote Link to comment Share on other sites More sharing options...
SiWhite Posted September 14, 2005 Share Posted September 14, 2005 It's the wieght I'm more concerned about - 715lbs excluding wire rope!!! Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted September 14, 2005 Share Posted September 14, 2005 Too expensive for starters. Its also too light and to small Oh and as for Lardy arse truck Mr Tonk Mke a sentence out of the following well chosen words : Lardy Portable yourself powerstation arse pot kettle black you On your LR Nige Quote Link to comment Share on other sites More sharing options...
Tonk Posted September 15, 2005 Share Posted September 15, 2005 i'm actually lightening mine (ok only slightly) at the mo Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted September 15, 2005 Share Posted September 15, 2005 wot ? you mean removing all the srpings and putting it on axle stands... well, that won't realy work will it now ? Nige Quote Link to comment Share on other sites More sharing options...
02GF74 Posted September 15, 2005 Share Posted September 15, 2005 wot ? you mean removing all the srpings and putting it on axle stands... well, that won't realy work will it now ? Nige no; he was referring to lightening his body (i.e. he is on the loo ) Quote Link to comment Share on other sites More sharing options...
Tonk Posted September 15, 2005 Share Posted September 15, 2005 wot ? you mean removing all the srpings and putting it on axle stands... well, that won't realy work will it now ? Nige no; he was referring to lightening his body (i.e. he is on the loo ) nah, its nige that needs to do that, no need to sit down though cos he talks it out Quote Link to comment Share on other sites More sharing options...
Tonk Posted September 15, 2005 Share Posted September 15, 2005 wot ? you mean removing all the srpings and putting it on axle stands... well, that won't realy work will it now ? Nige atleast it would be low enough to get in the garage Quote Link to comment Share on other sites More sharing options...
