geoffbeaumont Posted December 7, 2006 Share Posted December 7, 2006 Yesterday the rangie's steering was fine - this morning it's...not so great... It's okay close to centre, but loads up rapidly as I turn it, and can be just as hard to turn back. I can't see anything wrong under the truck. IIRC that's about the right symptoms for a shot/out of adjustment power steering unit, isn't it? Quote Link to comment Share on other sites More sharing options...
dollythelw Posted December 7, 2006 Share Posted December 7, 2006 UJ's Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted December 7, 2006 Author Share Posted December 7, 2006 UJ's *rse! That sounds slightly more dangerous to drive than a shot power steering box Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 7, 2006 Share Posted December 7, 2006 I hear WD40 is a good bet for "repair" Quote Link to comment Share on other sites More sharing options...
Lewis Posted December 7, 2006 Share Posted December 7, 2006 UJ's are fairly cheap IIRC, so you may aswell change them, Ive even got a couple of spares somewhere you can have if you are feeling the christmas pinch Lewis Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted December 7, 2006 Author Share Posted December 7, 2006 UJ's are fairly cheap IIRC, so you may aswell change them, Ive even got a couple of spares somewhere you can have if you are feeling the christmas pinch Lewis It's not the cost - it's the fact that I'm currently 25miles from home with no tools, so if it isn't safe to drive it'll be a yellow taxi job... Quote Link to comment Share on other sites More sharing options...
Lewis Posted December 7, 2006 Share Posted December 7, 2006 It's not the cost - it's the fact that I'm currently 25miles from home with no tools, so if it isn't safe to drive it'll be a yellow taxi job... If your 25mile drive takes you anywhere near staffordshire then swing by, ive got tools, and spares if i can find them Its two 13mm's if you can get hold of a spanner Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted December 7, 2006 Author Share Posted December 7, 2006 If your 25mile drive takes you anywhere near staffordshire then swing by, ive got tools, and spares if i can find them Its two 13mm's if you can get hold of a spanner No-where near, I'm afraid - I could probably go into town and get a couple of UJs and borrow spanners, but I think it'll get me home. Looks like the bottom UJ is knackered. Wonder if it'll last one more day...it's back off the road then, hopefully. Quote Link to comment Share on other sites More sharing options...
dollythelw Posted December 7, 2006 Share Posted December 7, 2006 can of WD, someone in the cab spinning the wheel from left to right and hose them both down with WD40, then get groovey with some engine oil - they will last a good while yet, 2 minute fix tops! Quote Link to comment Share on other sites More sharing options...
Andy Posted December 7, 2006 Share Posted December 7, 2006 WD40/3in1/Engine Oil - pour it over the UJs, that fix has worked for me for four years, just repeat every 3 months. btw one of my UJs is totally shot, hence my steering shake. Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted December 10, 2006 Author Share Posted December 10, 2006 A dose of WD40 has improved things considerably, but it's still noticeable so I ordered what I thought were the correct parts from MM4x4. Wrong... The UJs I ordered (NRC7704) are, I think, lower UJs from earlier Range Rovers, although I can't see any difference between them and the top UJ on mine. Unfortunately it's the bottom one that's knackered... As far as I can see from the parts manual, the top UJ for mine ('93 RR, KA VIN) is NRC7386, but the bottom one is only available as part of the complete shaft kit NTC8478, which is about £40 (up to about £70 at some places - and that was a Britpart one, too ). Does anyone know if it's possible to get just the lower UJ? Quote Link to comment Share on other sites More sharing options...
bishbosh Posted December 10, 2006 Share Posted December 10, 2006 AFAIK it is only available as part of a kit - I'm still licking the wound after replacing mine a few months back.... Quote Link to comment Share on other sites More sharing options...
