DiscoDino Posted July 12, 2017 Share Posted July 12, 2017 Well, after 3 years of sourcing, building and assembly...we've tested the rig enough to do a good beat down...here's the video: https://www.youtube.com/watch?v=UAEs6Ojo77cLots of great tech from Hardline...so hope you like it...now: need some stickier/skinner big tires! Quote Link to comment Share on other sites More sharing options...
30psi Posted July 12, 2017 Share Posted July 12, 2017 Epic. Quote Link to comment Share on other sites More sharing options...
elbekko Posted July 13, 2017 Share Posted July 13, 2017 Nice! Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted July 14, 2017 Share Posted July 14, 2017 (edited) I can see which bit is still Land Rover, it became obvious when the defender door didn't stay shut That's a serious bit of kit you've created Would it be worth trying the tyres with a bit less air in them? On some of the rocks they look a bit hard but then on others you can see the side walls start to crease so I'm not sure if it's a good idea or not? Edited July 14, 2017 by Cynic-al Quote Link to comment Share on other sites More sharing options...
DiscoDino Posted July 14, 2017 Author Share Posted July 14, 2017 1 hour ago, Cynic-al said: I can see which bit is still Land Rover, it became obvious when the defender door didn't stay shut That's a serious bit of kit you've created Would it be worth trying the tyres with a bit less air in them? On some of the rocks they look a bit hard but then on others you can see the side walls start to crease so I'm not sure if it's a good idea or not? Hey - yeah, that door striker needs changing :)... Yes, we started with 8psi, then 4psi, then 3psi, and we wanted to go lower but the gauge didn't go that low...Got me a 0.5psi increments gauge and receiving that next week...very fair observation you are 100% correct...also, despite the 3T weight, the tires seem to have too much floatation, may need some grooving... Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted July 15, 2017 Share Posted July 15, 2017 Great to see it out running! I really liked that Land Rover touch as well ? please don't fix the striker ? The tyres will get softer from use, also keeping then out in the sun as much aw possible helps the ageing which makes them softer. Quote Link to comment Share on other sites More sharing options...
