xychix Posted October 26, 2017 Share Posted October 26, 2017 It appears the webshops I try for a set of good bearings all ar out of stock / no longer available. I'm after a set (or 3 if they are this hard to come by) RTC3416 and RTC3426 (<1980 hub bearings). not available at: johncraddockltd, paddocks, and-rover-parts-shop.com and several dutch parties I checked. As it needs to be send to the Netherlands I always prefer to buy at a 'bigger' web shop so I can properly fill my box before having it send. Any hints on where to look? Quote Link to comment Share on other sites More sharing options...
Davethelandy Posted October 26, 2017 Share Posted October 26, 2017 Try a local machinery shop, they should be able to get you sorted Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 27, 2017 Share Posted October 27, 2017 Most LR bearings are nothing too special, local bearing shop/trade counter should be able to get them although proper industrial bearings attract proper industrial prices compared to the stuff turned out by the lowest bidder for Britpart... Biggest problem in Europe will be the daft imperial sizes. Quote Link to comment Share on other sites More sharing options...
xychix Posted October 27, 2017 Author Share Posted October 27, 2017 I Guess I'll go with the NTN bearings from: http://www.land-rover-parts-shop.com/en/ui/search.php?q=RTC3426G&stp=shttp://www.land-rover-parts-shop.com/en/ui/search.php?q=RTC3416G&stp=s the biggest difference seems that these are fixed in their race (or how is that outer layer the bearings roll in called?) Quote Link to comment Share on other sites More sharing options...
western Posted October 27, 2017 Share Posted October 27, 2017 Try these guys https://www.bearingboys.co.uk/Tapered-Roller-Bearings-1014-c hub bearings are inner race,bearings & cage, which fit inside the outer race which is usually seperate & is pressed into the hub. Quote Link to comment Share on other sites More sharing options...
AV8R Posted October 28, 2017 Share Posted October 28, 2017 On 26-10-2017 at 9:34 AM, xychix said: not available at: johncraddockltd, paddocks, and-rover-parts-shop.com and several dutch parties I checked. As it needs to be send to the Netherlands I always prefer to buy at a 'bigger' web shop Any hints on where to look? You might try Googling "kegellagers engelse maten" . Several dutch companies do offer Imperial sizes. Quote Link to comment Share on other sites More sharing options...
xychix Posted October 28, 2017 Author Share Posted October 28, 2017 Nice, now google for a while to learn how to measure bearrings or find a site that lists the land rover bearings for me Quote Link to comment Share on other sites More sharing options...
Pepé le Pew Posted October 29, 2017 Share Posted October 29, 2017 (edited) All bearings have numbers stampt on de inner and outer race, and all bearing manufacturers use the same numbers. The RTC numbers are just Land Rover part numbers. The bearing numbers for the RTC3416 and RTC3426 are. RTC3416: Outer race 354X. bearing(inner race) 359S. RTC3426: Outer race 11300. bearing(inner race) 11162. Any good bearing supplier will be able to get you good quality bearing using those numbers. Eric Edited October 29, 2017 by Pepé le Pew Quote Link to comment Share on other sites More sharing options...
