Bomag Posted December 11, 2006 Share Posted December 11, 2006 Ive been thinking about having this sorted out, it would make the whole trialling thing so much easier But, Im not a fan of the CPC kit, too much stuff hanging down screaming "RIP ME OFF" so what about using RR parts? I know AHL have done a conversion, but Ive not had a chance to look at it yet. How much would you pay to have someone else do the conversion for you? Quote Link to comment Share on other sites More sharing options...
Tonk Posted December 11, 2006 Share Posted December 11, 2006 i used to run the CP kit, had no problems on or off road. personally if you wanted to use lr stuff then i'd do it yourself, there is a bit of chopping and welding req'd which imo the chassis needs tubing so its strong enough. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 11, 2006 Share Posted December 11, 2006 If you fit RR power steering, then you have to use everything if I remember right. You also need to move the front crossmember forwards 5-inches to allow fitment of the PAS box on the chassis rail. There was a topic in LRO a few years ago now, and it was very detailed. Les. Quote Link to comment Share on other sites More sharing options...
Tonk Posted December 11, 2006 Share Posted December 11, 2006 you will also have to use a defender steering column obviously Quote Link to comment Share on other sites More sharing options...
Jon White Posted December 11, 2006 Share Posted December 11, 2006 Either chop out the frotn x-member and fit any fangie PAS box, or it is possible to fit by just cutting a wedge out of the front x-member if you use the right box. I'm running defender steering on mine and it works well, but not for the faint hearted as its alot of work and alot of safety critical cutting and welding! Bomag, if you're coming to Broxhead on the 27th you're welcome to come and collar me and have a look at mine. Cheers Jon Quote Link to comment Share on other sites More sharing options...
Tonk Posted December 11, 2006 Share Posted December 11, 2006 Bomag, if you're coming to Broxhead on the 27th you're welcome to come and collar me and have a look at mine.Cheers Jon i'd suggest before jon rolls it too Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted December 11, 2006 Share Posted December 11, 2006 Maybe after it'll be easier to see. Quote Link to comment Share on other sites More sharing options...
jericho Posted December 11, 2006 Share Posted December 11, 2006 Just a suggestion - link No cutting of crossmember. If taking this route,you might be better off soucing a slimmer steering box (toyota,or p38 maybe).I had to fit wheel spacers to make room for the box on full lock/full articulation. Quote Link to comment Share on other sites More sharing options...
Bomag Posted December 12, 2006 Author Share Posted December 12, 2006 Cheers guys, Toyota parts can NOT be used, only Rover parts allowed. The cutting and welding are the reasons why I was going to get AHL to do it. Jon, Im aiming to be at Broxhead, but the wifes now saying shes working so wont be able to look after the dogs As soon as she sorts her holiday out Ill let you know Quote Link to comment Share on other sites More sharing options...
tiagoc Posted December 12, 2006 Share Posted December 12, 2006 Just a suggestion - link No cutting of crossmember. If taking this route,you might be better off soucing a slimmer steering box (toyota,or p38 maybe).I had to fit wheel spacers to make room for the box on full lock/full articulation. can you explain the PAS setup you have? (detail of the parts used and all connections, with photos, would be great! ) and I just saw that you have heated windscreens. how does that work? Quote Link to comment Share on other sites More sharing options...
jericho Posted December 12, 2006 Share Posted December 12, 2006 can you explain the PAS setup you have? (detail of the parts used and all connections, with photos, would be great! )and I just saw that you have heated windscreens. how does that work? Have a look at TeriAnn Wakeman's article on series landrover pas conversion link I did much the same,but used rover parts - defender column and middle link (shortened slightly) and defender 6 bolt lhd steering box.If your vehicle is lhd,you will have to use a rhd box. If you want more details,please ask. Too dark and wet for photos just now. Heated windscreen works the same as heated rear window,but with very fine wire elements. Quote Link to comment Share on other sites More sharing options...
Tonk Posted December 13, 2006 Share Posted December 13, 2006 Heated windscreen works the same as heated rear window,but with very fine wire elements. worth the upgrade? Quote Link to comment Share on other sites More sharing options...
Bomag Posted December 13, 2006 Author Share Posted December 13, 2006 Horay, the wifes got the day off So Ill be at Broxhead in the big yellow one, and the wife will be there in the the Discovery commercial. Looking forward to a good day out. Quote Link to comment Share on other sites More sharing options...
Jon White Posted December 13, 2006 Share Posted December 13, 2006 Woohoo!!! You still driving that ratty yellow 2a with the external cage on it? Jon Quote Link to comment Share on other sites More sharing options...
jericho Posted December 13, 2006 Share Posted December 13, 2006 worth the upgrade? Going a bit off topic here,but yes - I drive mine every day,and so for £95 inc vat and delivery for the two screens it was definitely worth while.But then again,I have no heater,so maybe I need it more than most. Quote Link to comment Share on other sites More sharing options...
Tonk Posted December 14, 2006 Share Posted December 14, 2006 where did you get them for that price? Quote Link to comment Share on other sites More sharing options...
jericho Posted December 14, 2006 Share Posted December 14, 2006 where did you get them for that price? UROGLAS link But I notice they are now £124.55 per pair Quote Link to comment Share on other sites More sharing options...
Tonk Posted December 14, 2006 Share Posted December 14, 2006 they were the only ones i could find Quote Link to comment Share on other sites More sharing options...
