300 tdi PAS
The power steering has started to play up on my hi-cap. On the one hand I thought it may be the steering column joints as it tends to be stiff, loose, stiff, loose when doing slow turns like 3-point, but on the other hand if increase the revs it tends to loosen up which I thought would indicate the pump. Any ideas? Are the pumps servicable? It can also be stiff when slowing down to turn on tight corners.
If I need to replace the pump are the ZF OK?
