propshaft
Hi all , finally changed my prop today ( should have done it earlier really  :blush: ) for the one that James very kindly gave me on my 110 200tdi but they aren't the same .
This is the one I took off
and this is the one that James gave me off his project which was a 200tdi I believe
 and side by side
the one I removed is a larger diameter tube , but both fit . I am presuming that the one James gave me is the correct one for a 200tdi 110 , so what vehicle is the one I've removed from my 110 for ? Or is that the correct one and the other is wrong . any Help but be appreciated .
cheers Ian
The one James gave you is what they normally look like. The larger one looks more like a 130 prop. So assuming they are the same length then fit James's. Your original could be a cut down 130 one or just some sort of heavy duty one I haven't seen before.
Mike
